Topic: Solar Panel (Read 501 times) previous topic - next topic
Solar Panel
A friend has a solar panel for me, if I would like it.  It just sounds enormous and maybe over kill.  Any thoughts?  It's 340 watts and 78.5 x 39.4.  We have a RK.
Re: Solar Panel
Well, the answer is for someone to get up on the roof, with a tape measure, and see if the space is available.
Every LD's roof is a little different. RKs are somewhat rare.
Re: Solar Panel
"...A friend has a solar panel for me, if I would like it.  It just sounds enormous and maybe over kill..."
Marcie,
Solar panel overkill on a Lazy Daze? Is there such a thing?
You be the judge...
https://youtu.be/SJaSWG4juF8
https://youtu.be/fw1ISW6geqY
Think she's trying to operate a particle accelerator?
Just sayin!
Re: Solar Panel
Now that's hilarious
Re: Solar Panel
She seems pleased, though. Very creative.
I just wonder how the panels enjoy freeway speeds.
Re: Solar Panel
It is likely a commercial panel, and will require a top-notch solar controller rated for the voltage and power.  In general, more smaller panels are better for performance (and roof-fit) in conditions other than open desert, to avoid shading issues.
Re: Solar Panel
"It is likely a commercial panel, and will require a top-notch solar controller rated for the voltage and power."
Matching a solar charge controller, a multi-stage converter, and the appropriate battery set-up to this 340V panel were my first thoughts when I read the initial post.
A solar "system" is not just a panel or panels; even if there's space for the panel, a well-functioning system requires components that work together efficiently and the set-up needs to be planned out, matched, and wired together by someone who knows what he or she is doing. "Free" often isn't.
As ever, YMMV.
Re: Solar Panel
What's the panel voltage? If it's, say, 60 volts, the wiring to the regulator near the battery only has to handle 6 amps, easy to to do with 12 AWG wire. For that voltage panel, I'd suggest a MPPT charge regulator with a 70+ volt rating - very available. I think the biggest issue is mounting it.
2005 Jayco 24SS
Re: Solar Panel
Eric,
The panel - 43 volts.
Re: Solar Panel
Eric,
Victron makes  a controller that will work.
https://www.victronenergy.com/upload/documents/Datasheet-BlueSolar-charge-controller-MPPT-100-30-&-100-50-EN.pdf
Victron BlueSolar Charge Controller MPPT 100/30 - 30A at 12/24 Volts
The downside of having a panel with an odd voltage is if you ever want to add more panels, it will need to have the same voltage output, for best efficiency.
Panels are cheap today, compared to the prices of just a few years ago.
You might be better served buying panels that properly sized for the roof's real estate and of a more common output voltage.
Re: Solar Panel
Hi Larry. That sure is a nice controller. Shows how much MPPT controllers have improved. I bought mine in 1999 when most people had never heard of one. Mine was made by a company in Encinitas and cost more than this one. I don't think Marcie would need to add any more panels than just this one panel.
  I've only got about 130 watts, but I don't have the weight capacity for more batteries. RonB
Re: Solar Panel
340 watts might be enough, eh?    ;D
And since it's free, only the labor of installing it is lost if he decides he needs to replace it with more panels, as the controller would still do the job.
2005 Jayco 24SS
Re: Solar Panel
For many, no. Fulling timing in the winter can require much more solar, if you are a heavy user.
I was just pointing out this disadvantage. It hasn't been established if the panel will even fit the roof.
Re: Solar Panel
Sorry Larry, I meant to establish that it does fit. The panel goes to the edge on the 40.4 side.
Re: Solar Panel
Panels mounted close to the edge of the roof are vulnerable to tree branches.
A panel can be ripped off if a branch gets under the panel, while the rig is moving, such as in an overgrown campground.
Consider armoring the exposed side and leading edge as shown here,
IM007142 (Small) | lw5315us | Flickr
Panels need air space under them, for cooling. The hotter the panel, the lower the output efficiency.
