Topic: 97 TK solar (Read 162 times) previous topic - next topic
97 TK solar
So I did this install 6 months ago and just now took some pictures.  LG 310 watt, 32 volt solar panel with a blue sky controller.  I had water damage to the compartment where a generator could have gone.
(Sorry, but you are not allowed to access the gallery)
The only thing I am disappointed in is the amount of power generation under trees and rain/cloudy conditions.  I only see around 80 watts.  Is 26% what others get?  I had planned on adding another controller and 18 volt panels but we have never dropped to less than 92% of our capacity and that was after a rainy under tree weekend where the panel could not quite keep up.
1997 TK
Re: 97 TK solar
"The only thing I am disappointed in is the amount of power generation under trees and rain/cloudy conditions."
Just off the top of my head, what you're seeing sounds reasonable. Solar panels can't generate full power when shaded or in cloudy conditions.
Re: 97 TK solar
I know it was wishful thinking I could get more.  It does start charging with very little light being a 32 volt panel which is nice and when I install the inverter I'll add some more 100 Watt panels in the back and maybe some that I can move on the ground to get around a shady spot.
1997 TK
Re: 97 TK solar
Can't stop the rain, but certainly try to avoid trees. Potential damage from falling stuff is not worth the shade value.
Re: 97 TK solar
Camping up on pikes peak was worth it.  You can only do it once a year for the hill climb.  Glad I didn't have something larger as it was a slow tight fit to get our spot.
1997 TK
