Topic: Minor Changes (Read 280 times) previous topic - next topic
Minor Changes
The rubber grommet in the hole next to the gas cap needed to be replaced.  I found a perfect replacement at Lowes by Hillman, part number H#884628.  The Lowes sku is 38902 00388.  Picture is attached.
Following the guidance of several other LDO's, we replaced the Smoke and CO detectors (which may have been OEM) with a single unit from Kidde, Model P3010K-CO.  This is the Kitchen model which is suppose to reduce kitchen nuisance alarms and is a combination detector using Photoelectric Technology.  Picture attached.  I've patched the screw holes on the missing alarm and after it dries, we'll touch it up to match the ceiling as suggested by Larry W.
And that's all I've to say about that.
Re: Minor Changes
I could use that grommet. I have tried searching on Lowe's site using all the numbers and part but come up with nothing. Can you tell me where in the store you found it?
Jim
Re: Minor Changes
Try an online search for the Lowe's in your area.
The Hillman Group 2-Pack 9/32 Rubber Grommets
Item # 423514 Model # 884628
2002 27" RB
Re: Minor Changes
This matches up with my receipt.  I copied information off of the package.  The direct link is:
Shop The Hillman Group 2-Pack 9/32 Rubber Grommets at Lowes.com
I apologize for the lack of specificity.  : (
Re: Minor Changes
Jim ... if you send me a message with your home address, I'll mail you one of these grommets.  My package had two (2) and I only need one.
Thanks for your kind offer. We will be going by a Lowe's today and according to the site they have these available.
You may find that you need that other one in a few years.
Jim
