Topic: Screen (Read 190 times) previous topic - next topic
Screen
We just bought an LD!!! It's a 2997 MN and it is missing the screen on the window next to the dinette area. I have some searching but can't find any info on getting a replacement. Any suggestions?
Melissa
Re: Screen
2997 MN?
Re: Screen
Call the mothership and find out if they have any spares available.
2011 MB
Re: Screen
Is the black metal frame missing, or just the screening material inside the frame? If the latter, screening is available at most hardware stores, and is fairly easy to install. You'll need a roll of the screening material, some "spline" (be sure to get the correct diameter), and a roller tool to install it. A large flat work area makes the job easier. Total cost should be under twenty bucks.
Re: Screen
By the way, congrats on your new rig! :-) I'm assuming it's a 1997 midbath, correct?
Re: Screen
Yes, sorry 1997 MB.
Melissa
Re: Screen
The frame is missing. I will call LD and see what I can find out.  Thanks!
Melissa
Re: Screen
The sliding screen is specific to to the window and its track and is not a generic screen.
You might want to contact Hehr windows to see if the screen is still available.
Window Products
Re: Screen
Thank you! I sent them an email.
Melissa
