Topic: Fuel Capacity and Storage (Read 257 times) previous topic - next topic
Does anyone know the amount of fuel the 26 mid bath carries and does anyone have an estimate on the cubic feet of external storage available?
Chesapeake, VA
Re: Fuel Capacity and Storage
You'll find a ton of answers to almost all of your questions about LD's here...
The Lazy Daze Companion
Go to the bottom of the page and click on "the web version".
And at the Lazy Daze web page here...
Motorhome Dealer | Low Profile Motorhome | RV Manufacturer | Quality Motorhome Just click on the image and all LD has is there.
Granted that your year and model may not be an exact match to the info available, but it's a great source of information. (I hope the links open for you, sometimes I don't get this just right)
Others here may be able to give you a more direct answer to your question.
Enjoy the read,
It varies with year/chassis, and layout within the MB. Can you give more specifics? I see you have a Twin King? Are you making a comparison? The LD Companion that Kent referred you to has a lot of accurate information. Like the LD manual, it bears reading and re-reading.
My ,92 E350 fuel tank is rated to be 36 gal. I would go out and measure all my compartments, but I just emptied, cleaned and repacked them yesterday.
Paul
'92 Mid Bath
Ok, I found that the new LDs have a 55 gallon fuel tank.  I did not find any info on the cubic feet of outside storage.
Chesapeake, VA
funpilot, the storage compartments vary by year, model and configuration. In older LDs the boxes were made by LD out of plywood so they were tailored to the space available.  Are you looking to build a data base, or comparing models, or do you have a specific unit in mind? I don't mind rooting around in mine and measuring the compartments, but if it is of no help to your cause I will spend the time finishing packing.
Will my 1992 26-½ MB on the old (narrow) E350 chassis, with the barrel chairs in the the lounge option help you?
You mention the new LDs have a 55 gallon fuel tank, so I infer you are interested in data from some year newer than '92, and on an E450 chassis?
Paul
'92 Mid Bath
Funpilot,
Here is a link to Andy's 1985  22' but like Paul said...it may not fit your situation.
I do recall quite a lengthy discussion of storage space dimensions shorty before the bail from Yahoo. You may be able to fish around the "Yahoo Archives" to get more accurate data.
At any rate...here is Andy's link:  Gertie: a guided tour
Best of luck finding what you want.
Go to Community, click on it and then click on Search. Put in "compartment dimension". Select "any words". You will find many posts discussing compartment dimensions.
Chris, your search instructions work well, brought up the dimensions for several models. So I will add mine here for future searching:
1992 MB external storage dimensions
RR corner
opening- 39 x 9-1/2
30-½ D x 61- ½ L x 11-¾ H
Behind RR wheel
Opening 28-½ x 8-½
 12-½ D x 39-½ L x 11 H
Battery- R side in front of door
Opening 16/½ x 14
12 D x 18-¾ L x 15-½ H
R front corner
Opening 23/¾ x 10
19-½ D x 30-½ L x 11-½ H
L front corner
28-¾ x 8-½
22-½ D x 35-¼ L x 12 H
Paul
'92 Mid Bath
Here are storage dimensions for my 2003 midbath:
INTERIOR
Overcab: 45" wide x 11.5" deep x 3" high (1,552 c.i.)
Fridge: 6 cu. ft. (10,368) c.i.
Drawer under fridge: 17.5" wide x 11" deep x 5" high (962 c.i.)
Cupboard under fridge: 21" wide x 12" deep x 14" high (3,528 c.i.)
Two drawers under sink: 8.5" wide x 17.5" deep x 5" high (1,488 c.i.)
Under sink storage: 23" x 35" by 13" high, with one corner cut off (9,000 c.i.)
Cupboard over stove: 25.5" wide x 14" deep x 16" high (5,712 c.i.)
    (8" deep shelf starts at about 7" height)
Cupboard above sink: 26" wide x 9.5" deep x 20" high (4,940 c.i.)
    (9.5" shelf starts at 9" height and divides space in two)
Storage under short dinette seat: 23.5" wide x 29" deep x 14" high (9,541 c.i.)
Cupboard above dinette: 13" deep x 12" high x 69" wide (10,764 c.i.)
Pantry cupboard: 20" wide x 5" deep x 27.5" high (2,750 c.i.)
    (with four adjustable-height plastic bins)
Wardrobe: minimum usable space 38" wide x 23" deep x 41" high (to bottom of shelf) (35,834 c.i.)
    plus shelf 43" wide x 10" deep x 9" high (3,870 c.i.)
    plus side shelf 24" wide x 5" deep  x 8.5" high (3,655 c.i.)
Upper left drawer under wardrobe: 13.5" x 20.5" deep x 5" high
Upper right two wardrobe drawers: 17.5" wide x 20.5" deep x 5" high (3,587 c.i.)
Lower right wardrobe drawer: 11.5" wide x 20" deep x 5" high (1,150 c.i.)
Cupboard over bathroom sink: 39" wide x 8" deep x 9" high (2,808 c.i.)
Bathroom storage bins:
    24" wide x 3" deep x 11" high (792 c.i.)
    24" wide x 3" deep x 7" high (504 c.i.)
    24" wide x 6" deep x 6" high (864 c.i.)
Bathroom under-sink storage (bisected by shelf):
    14" wide x 9" deep x 14" high but with drain trap hanging down (1,600 c.i.)
    14" wide x 9" deep x 14" high unencumbered (1,764 c.i.)
Storage behind curbside sofa (wedge-shaped): 79" wide x 8" deep x 13" high (8,216 c.i.)
Storage behind streetside sofa (wedge-shaped): 73" wide x 8" deep x 13" high (7,592 c.i.)
Cabinet over curbside sofa: 57" wide x 12" deep x 14" high (9,576 c.i.)
Cabinet over rear window: 57" wide x 12" deep (but with upper curve) x 13" high (9,576 c.i.)
    plus about 1,600 c.i. of hard-to-access space on each side (3,200 c.i.)
Cabinet over streetside sofa: 34" x 15.5" deep x 14" high (7,378 c.i.)
13" TV/VCR cabinet: 18" wide x 15" high x 13" deep (3,510 c.i.)
EXTERIOR
Curbside rear compartment: 30" wide (spare tire takes up rest of width) x 30.5" deep x 13" high (11,895 c.i.)
Curbside compartment below water heater: 55" wide x 18" deep x 12" high (11,880 c.i.)
Curbside compartment under long dinette seat (also accessible from inside by lifting seat cushion): 23" wide x 41" deep x 15" high (14,145 c.i.)
Streetside compartment below fridge and battery access doors: 35" wide x 19" deep x 14" high (9,310 c.i.)
Streetside rear compartment (under sofa, but not accessible from inside): 66" wide x 25" deep x 13" high (21,450 c.i.)
Streetside lower rear compartment:  35" wide x 12" deep x 12" high (5,040 c.i.)
Storage space under spare cover: 38" wide x 4-8" deep x 27" high (6,156 c.i.)
Total: 142 cubic feet
 Andy,
To quote a few iconic figures: "That's what I'm talkin' about".
Who else...where else would you find a group of dedicated RV owners of any kind that would take the time to provide such rock solid information?
Not sure I will ever be able to do what you have done...but you do inspire me.
Now where did I put that tape measure, pen...paper? Oh my... :-[
