Topic: Did I mess up something removing my swamp cooler? (Read 216 times) previous topic - next topic
Hi,
I have a 1992 MB that I've owned for about 8 years.  I finally got around to removing the old swamp cooler and replacing it with a new fantastic fan.  All went well after wrestling the old bugger out.  I taped off uneaded wires and all works well.  However, this weekend camping, my hot water heater would not light.  Does anyone know if there some wiring associated with the water heater that goes through the wiring that is hooked up to the swamp cooler?
Thanks,
Jerry
1992 MB
Re: Did I mess up something removing my swamp cooler?
Have you checked the fuses, in the Power Center?
Normally, the fuse's locations and functions are listed inside the Power Center's hinged cover.
It's possible the water heater and swamp cooler where on the same fuse.
Are either of the water heater's indicator lights illuminated, when switched on?
The fuse is fine.  In my oldie but goodie, the light comes on briefly and then goes off if the water heater lights correctly.  When it comes back on it indicates a fault.  I can hear the ignitor click, click, click and then the light comes back on.
1992 MB
Seems the problem is in the water heater, not the wiring.
Check this Atwood trouble shooting guide.
http://manuals.adventurerv.net/Atwood-Water-Heater-Service.pdf
Clean the electrical contacts and check the thermal fuse and temperature sensors for continuity.
If the control board turns out to be bad,replace it with a Dinosaur Board, instead of the stock Atwood board.
Dinosaur boards are built to higher standards and are highly recommended..
Dinosaur Electronics Home. High quality circuit boards for RV appliances.
All that Larry said, and if the ignitor is clicking but not igniting, the problem could also be a blocked burner tube or jet (orifice) that doesn't allow the gas to get to the ignitor. (Spiders love the smell of mercaptan, the odorant used for propane, and often make webs/nests in water heater and refrigerator burner tubes.) You might want to soak the orifice in a little alcohol and blow out the tube and orifice with compressed air; don't poke anything into the jet orifice..
Do you know how old the propane regulator is? I had a problem with the installed propane furnace in a trailer I just sold that was being temperamental. Replacing the the regulator fixed the problem.
