Rear window rubber bead July 10, 2016, 05:03:27 pm Hi, former yahoo member "akmacs" but had to register as new. I need to order some of the rubber bead for my fixed rear window. I'm taking it to a glass shop to have the three glass peices removed/resealed and want to replace the rubber seal since it has shrunk and hardened. Does anyone know what the correct part would be. I found this Hehr 3/16" Glazing Bead - Window Parts and it looks right but wondered if anyone knew for sure. There are weep holes in the current bead that I guess must be cut by hand in the new bead.My coach is a 1997 23.5 T/KThank you,Mike
Re: Rear window rubber bead Reply #1 – July 10, 2016, 10:10:05 pm While you at it Mike, take a look at the sliding windows. I just had to replace a top screw on the passenger side large bay window. Actually it backed out and upon opening the molding popped off at the top. At some point I will take that sliding pane out and secure properly but it will have to do for now.Terry - '92 - 23.5' TK
Re: Rear window rubber bead Reply #2 – July 11, 2016, 02:39:53 am Terry, I have noticed some screws backing out on some windows and they are so rusty I'll just replace them with fresh zinc plated I think. I also noticed the sealant on the sliders is breaking down as well. I think its just at that age now.
