Topic: Parking brake reservoir fluid (Read 151 times) previous topic - next topic
Can't find the post that talked about lube points -- and Larry mentioned the brake reservoir.
Couldn't find anything about the type of oil to use:    engine oil, brake oil, trans oil?     Thanks.
2017 Newmar Canyon Star
2002 Lazy Daze MB
2005 Honda CRV Toad
Re: Parking brake reservoir fluid
You want to use automatic transmission fluid Mercon "V".  Should be filled to top of reservoir opening.
Checked mine last week.  Fluid looked a little burnt or dirty.  Does anyone know if the fluid should be changed or just filled?
Roger
While there is no specified change interval, periodic replacement would be a good idea if you can remove the old fluid.
There isn't a drain plug and there isn't much room inside the filler hole to stick a tube down into the reservoir, that would be used for pulling the old fluid out.  It's a really tight area to work in.
To ease filling, use a pump than fits in a bottle of trans fluid. It take very little to fill the reservoir.
Amazon.com: Plews 55001 Lubrimatic Fluid Quart Pump, Fits Standard Quart...
Thanks Larry,
I think I'll leave the fluid alone, for now.  If my transmission fluid looked the same as the fluid in the parking brake reservoir, I would definitely  know that it was long past due to change the ATF.  My 2004 LD has just 23,000 miles on it.
Roger
