Topic: 2015 Ford recall.  (Read 312 times) previous topic - next topic
2015 Ford recall.
If you have a LD with a 2015 chassis on order, be aware there is a recall you will want to find out about.
It's an Emission recall. 15E05.
Seems the software controlling some part of the emissions system needs an update.
Ed
Re: 2015 Ford recall.
Had the recall done today.
It's the Powertrain Control Module. Had to be reprogrammed. Took about an hour and a half.
The local Ford dealer does not service RV's because the lifts they have are not designed for the weights involved.
However, per the service writer, they are required by Ford to perform recall (and specifically not warranty) work if the required work is within the capabilities of their facility. Since this recall didn't require a lift, they did the work.
So, if you have recall work, and your neighborhood Ford dealer doesn't typically service RV's, they may well have to take care of you.
Ed
And you can check to see if there are any recalls on your RV by going to
owner.ford.com
Just got the notice on my 2011. Good to know the local Ford dealer will be forced to do it.
Lori Y
2011 24FL
Carnation WA
Lori Y
2011 24FL
owner.ford.com
This website has been down now for 2 days. Wonder if Ford is swamped.
Rick and Melissa
2016 27ft RB
Ed
Hi
How did your LD run after the fix?  Any change in gas mileage?  We got our notice and making arrangements for the repair now.  We just wondered if our mileage will suffer as a result.
Thanks Corky
2013 TK
Hi
Thanks Corky
I don't keep track of my mileage. It is what it is.
I saw no change in engine performance at all.
Ed
