Topic: Bathroom Faucet Leak - Solved (Read 207 times) previous topic - next topic
Several times in recent months we've found small amounts of moisture under the sink cabinet.  For example, wet toilet paper.  I checked alll the fittings, ran water while watching for drips, etc.  Turns out that when water was splashed behind the top of the faucet, it leaked under the rear faucet gasket.  While the faucet is tightly fastened to the counter, the rubber gasket was not tight.  So a small bead of clear Kwik Seal Plus around the faucet base and we've been dry for a week.  This is a temporary fix until I can replace the rubber seal.
Re: Bathroom Faucet Leak - Solved
Thanks, that's good to know about.
