Topic: difference between "Dicor Self-Leveling Sealant" and "3M Marine Adhe (Read 97 times) previous topic - next topic
Yahoo Message Number: 159618
Hi all!
First, *many* thanks to all who participate in this forum. I'm learning SO MUCH from studying everyone's posts; I've repeatedly found answers to things I've wondered about in previous threads; and am grateful for the direct responses to my posts!
As regular maintenance, apparently it's time to reseal the roof on the 2002 LD MB we just bought, and I am confused as to the difference between Dicor Self-leveling Lap Sealant and 3M Marine Adhesive Sealant 5200. Are these for different purposes; or do folks have personal preferences? My apologies if this is a *really* dumb question. Someday I hope to be able to answer questions like you all! :)
Re: difference between "Dicor Self-Leveling Sealant" and "3M Marine
Yahoo Message Number: 159619
3M 5200 marine "fast cure" sealant/adhesive is used to seal cracks/splits in the fiberglass parts of the LD, e.g., the end caps or any area where a "corner wrap" has come loose from the body, to seal around vents, and to seal around window frames. The product is not appropriate to seal the seams on the LD's roof.
I can't speak to how well the Dicor lap sealant would work; I haven't used it and I can't say whether it's appropriate for use on an aluminum roof. Many, if not most, who have had the roof resealed have either used Eternabond or had the job done at the factory.
If you're considering using a "lap sealant", you might want to call the LD factory and ask Vince what they're using now on the roof seams; it may be the Dicor or a similar product, but he could offer the best advice about what to use. Be advised that the factory does NOT like Eternabond because the product is *extremely difficult* to remove if they are asked to do a repair of a previously Eternabonded area.
This link describes the Dicor product in question:
http://dicorproducts.com/catalog/roof-products/replace/epdm-lap-sealants/
Yahoo Message Number: 159622
Tobey,
Not sure about Dicor product but I've used 3M product successfully for our 2007 LD RB for resealing areas around windows, misc outlets, etc. I also used to seal up those thin stress cracks that appear on vertical corner pieces around the rv. Note: product has consistency of toothpaste when first applying it so pretty messy to work with.
John
Yahoo Message Number: 159651
Hi all! Thank you all for the clarifications, and thanks to Joan for the recommendation that I call Vince at the factory. I did so and wanted to share his "two cents":
I explained to him that we just purchased a 2002 LB MB, and that the person performing the inspection recommended we reseal the roof. The owner said he resealed it every two years and confirmed it was due.
I called a shop around here (Chicago), and they said they did not remove the old sealant for fear of damaging the roof. Instead, they scrubbed the old sealant and applied Dicor Self-Leveling sealant over the old sealant for $90/hr labor; $15/tube.
When I called Vince to ask about Dicor versus Eternabond and told him about the resealing of the roof, he groaned and asked if I really wanted to hear what he thought - LOL! He was with a customer, so when I called him back, he told me this:
It is true, he is not a fan of Eternabond, and says if he believed it worked, he would be using it at the factory. Another concern he has about Eternabond is that it is often used over old sealant rather than removing the old sealant. He believes this is the wrong way to do the job.
He also expressed concern about a roof being resealed every two years. He said the sealant used at the factory is expected to last 7-10 years.
Finally, he said his best recommendation was that we have the roof resealed at the factory while we are on a trip out west. He promised he was not just saying that to get more work, saying his shop was already full of rigs. But he said if we plan to keep the RV rather than use it and sell it in a year, he would highly recommend we bring it to the factory where they would strip out all the old sealant and use their product, with the expectation it would be done right and not have to be done again for 7-10 years, unless we decided to camp out in Death Valley for a summer. He did make an offhand reference to this being ~thousand dollar investment.
He was not familiar with Dicor, but said the product they are using at the shop is "Loctite PL S40" - and he couldn't give it enough high marks.
Very interested in others' thoughts, as well as direction to any resources about how to reseal a roof myself correctly. (The first video I watched showed someone putting a ton of caulk over old caulk and it ended up looking like a mess - but I don't know what I'm doing, so maybe that's just how it looks!?!?)
Thanks again all, and hope this is helpful!
Yahoo Message Number: 159655
Note that the Dicor product is an EPDM sealant, designed for RVs with EPDM (rubber) coated roofs.
Yahoo Message Number: 159656
I will stay with Eternabond and Dicor. Works for me.
This true removing the original sealant makes the Eternabond look better, but it's looks only.
Yahoo Message Number: 159657
Steve, Thanks for the Information about the Dicor Roof Sealent that it's for Rubber Coated Roofs and Not Metal Roofs for LD. Good to know..
JO
Yahoo Message Number: 159658
Tobey,I looked up "Loctite PL S40" and it looks like that product is for sealing around the windows but "Loctite PL S30" is for the Roof >> Loctite Products Mobile Product Advisor. Expert guidance to find the best adhesive, glue and sealing solutions.                                     Loctite Products Mobile Product Advisor. Expert guidance to find the best a...                    On Friday, April 1, 2016 4:34 PM, "Jo Blackmore redraven143@... [lifewithalazydazerv]"  wrote: Steve, Thanks for the Information about the Dicor Roof Sealent that it's for Rubber Coated Roofs and Not Metal Roofs for LD. Good to know.. JO      On Friday, April 1, 2016 3:41 PM, "dmalpas@... [lifewithalazydazerv]"  wrote: I will stay with Eternabond and Dicor. Works for me. This true removing the original sealant makes the Eternabond look better, but it's looks only.
ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536 -- ygrps-yiv-506578884yiv8019544536ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mkp hr { border:1px solid #d8d8d8;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mkp #ygrps-yiv-506578884yiv8019544536hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mkp #ygrps-yiv-506578884yiv8019544536ads { margin-bottom:10px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mkp .ygrps-yiv-506578884yiv8019544536ad { padding:0 0;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mkp .ygrps-yiv-506578884yiv8019544536ad p { margin:0;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mkp .ygrps-yiv-506578884yiv8019544536ad a { color:#0000ff;text-decoration:none;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-sponsor #ygrps-yiv-506578884yiv8019544536ygrp-lc { font-family:Arial;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-sponsor #ygrps-yiv-506578884yiv8019544536ygrp-lc #ygrps-yiv-506578884yiv8019544536hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-sponsor #ygrps-yiv-506578884yiv8019544536ygrp-lc .ygrps-yiv-506578884yiv8019544536ad { margin-bottom:10px;padding:0 0;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536actions { font-family:Verdana;font-size:11px;padding:10px 0;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536activity span { font-weight:700;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536activity span:first-child { text-transform:uppercase;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536activity span a { color:#5085b6;text-decoration:none;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536activity span span { color:#ff7900;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536activity span .ygrps-yiv-506578884yiv8019544536underline { text-decoration:underline;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 .ygrps-yiv-506578884yiv8019544536attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 .ygrps-yiv-506578884yiv8019544536attach div a { text-decoration:none;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 .ygrps-yiv-506578884yiv8019544536attach img { border:none;padding-right:5px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 .ygrps-yiv-506578884yiv8019544536attach label { display:block;margin-bottom:5px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 .ygrps-yiv-506578884yiv8019544536attach label a { text-decoration:none;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 blockquote { margin:0 0 0 4px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 .ygrps-yiv-506578884yiv8019544536bold { font-family:Arial;font-size:13px;font-weight:700;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 .ygrps-yiv-506578884yiv8019544536bold a { text-decoration:none;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 dd.ygrps-yiv-506578884yiv8019544536last p a { font-family:Verdana;font-weight:700;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 dd.ygrps-yiv-506578884yiv8019544536last p span { margin-right:10px;font-family:Verdana;font-weight:700;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 dd.ygrps-yiv-506578884yiv8019544536last p span.ygrps-yiv-506578884yiv8019544536yshortcuts { margin-right:0;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 div.ygrps-yiv-506578884yiv8019544536attach-table div div a { text-decoration:none;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 div.ygrps-yiv-506578884yiv8019544536attach-table { width:400px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 div.ygrps-yiv-506578884yiv8019544536file-title a, #ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 div.ygrps-yiv-506578884yiv8019544536file-title a:active, #ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 div.ygrps-yiv-506578884yiv8019544536file-title a:hover, #ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 div.ygrps-yiv-506578884yiv8019544536file-title a:visited { text-decoration:none;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 div.ygrps-yiv-506578884yiv8019544536photo-title a, #ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 div.ygrps-yiv-506578884yiv8019544536photo-title a:active, #ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 div.ygrps-yiv-506578884yiv8019544536photo-title a:hover, #ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 div.ygrps-yiv-506578884yiv8019544536photo-title a:visited { text-decoration:none;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 div#ygrps-yiv-506578884yiv8019544536ygrp-mlmsg #ygrps-yiv-506578884yiv8019544536ygrp-msg p a span.ygrps-yiv-506578884yiv8019544536yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 .ygrps-yiv-506578884yiv8019544536green { color:#628c2a;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 .ygrps-yiv-506578884yiv8019544536MsoNormal { margin:0 0 0 0;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 o { font-size:0;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536photos div { float:left;width:72px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536reco-category { font-size:77%;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536reco-desc { font-size:77%;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 .ygrps-yiv-506578884yiv8019544536replbq { margin:4px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mlmsg table { font-size:inherit;font:100%;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mlmsg select, #ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 input, #ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 textarea { font:99% Arial, Helvetica, clean, sans-serif;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mlmsg pre, #ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 code { font:115% monospace;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mlmsg * { line-height:1.22em;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-mlmsg #ygrps-yiv-506578884yiv8019544536logo { padding-bottom:10px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-msg p a { font-family:Verdana;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-msg p#ygrps-yiv-506578884yiv8019544536attach-count span { color:#1E66AE;font-weight:700;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-reco #ygrps-yiv-506578884yiv8019544536reco-head { color:#ff7900;font-weight:700;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-reco { margin-bottom:20px;padding:0px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-sponsor #ygrps-yiv-506578884yiv8019544536ov li a { font-size:130%;text-decoration:none;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-sponsor #ygrps-yiv-506578884yiv8019544536ov li { font-size:77%;list-style-type:square;padding:6px 0;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-sponsor #ygrps-yiv-506578884yiv8019544536ov ul { margin:0;padding:0 0 0 8px;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-text { font-family:Georgia;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-text p { margin:0 0 1em 0;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-text tt { font-size:120%;} ygrps-yiv-506578884 #ygrps-yiv-506578884yiv8019544536 #ygrps-yiv-506578884yiv8019544536ygrp-vital ul li:last-child { border-right:none !important;} ygrps-yiv-506578884
Yahoo Message Number: 159659
"Loctite PL S40"  >> Loctite Products Mobile Product Advisor. Expert guidance to find the best adhesive, glue and sealing solutions.                                     Loctite Products Mobile Product Advisor. Expert guidance to find the best a...                   On Friday, April 1, 2016 4:43 PM, "Jo Blackmore redraven143@... [lifewithalazydazerv]"  wrote: Tobey,I looked up "Loctite PL S40" and it looks like that product is for sealing around the windows but "Loctite PL S30" is for the Roof >> Loctite Products Mobile Product Advisor. Expert guidance to find the best adhesive, glue and sealing solutions.                  Loctite Products Mobile Product Advisor. Expert guidance to find the best a...             On Friday, April 1, 2016 4:34 PM, "Jo Blackmore redraven143@... [lifewithalazydazerv]"  wrote: Steve, Thanks for the Information about the Dicor Roof Sealent that it's for Rubber Coated Roofs and Not Metal Roofs for LD. Good to know.. JO      On Friday, April 1, 2016 3:41 PM, "dmalpas@... [lifewithalazydazerv]"  wrote: I will stay with Eternabond and Dicor. Works for me. This true removing the original sealant makes the Eternabond look better, but it's looks only.
ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088 -- ygrps-yiv-640288664yiv5666105088ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mkp hr { border:1px solid #d8d8d8;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mkp #ygrps-yiv-640288664yiv5666105088hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mkp #ygrps-yiv-640288664yiv5666105088ads { margin-bottom:10px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mkp .ygrps-yiv-640288664yiv5666105088ad { padding:0 0;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mkp .ygrps-yiv-640288664yiv5666105088ad p { margin:0;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mkp .ygrps-yiv-640288664yiv5666105088ad a { color:#0000ff;text-decoration:none;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-sponsor #ygrps-yiv-640288664yiv5666105088ygrp-lc { font-family:Arial;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-sponsor #ygrps-yiv-640288664yiv5666105088ygrp-lc #ygrps-yiv-640288664yiv5666105088hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-sponsor #ygrps-yiv-640288664yiv5666105088ygrp-lc .ygrps-yiv-640288664yiv5666105088ad { margin-bottom:10px;padding:0 0;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088actions { font-family:Verdana;font-size:11px;padding:10px 0;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088activity span { font-weight:700;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088activity span:first-child { text-transform:uppercase;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088activity span a { color:#5085b6;text-decoration:none;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088activity span span { color:#ff7900;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088activity span .ygrps-yiv-640288664yiv5666105088underline { text-decoration:underline;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 .ygrps-yiv-640288664yiv5666105088attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 .ygrps-yiv-640288664yiv5666105088attach div a { text-decoration:none;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 .ygrps-yiv-640288664yiv5666105088attach img { border:none;padding-right:5px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 .ygrps-yiv-640288664yiv5666105088attach label { display:block;margin-bottom:5px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 .ygrps-yiv-640288664yiv5666105088attach label a { text-decoration:none;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 blockquote { margin:0 0 0 4px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 .ygrps-yiv-640288664yiv5666105088bold { font-family:Arial;font-size:13px;font-weight:700;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 .ygrps-yiv-640288664yiv5666105088bold a { text-decoration:none;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 dd.ygrps-yiv-640288664yiv5666105088last p a { font-family:Verdana;font-weight:700;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 dd.ygrps-yiv-640288664yiv5666105088last p span { margin-right:10px;font-family:Verdana;font-weight:700;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 dd.ygrps-yiv-640288664yiv5666105088last p span.ygrps-yiv-640288664yiv5666105088yshortcuts { margin-right:0;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 div.ygrps-yiv-640288664yiv5666105088attach-table div div a { text-decoration:none;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 div.ygrps-yiv-640288664yiv5666105088attach-table { width:400px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 div.ygrps-yiv-640288664yiv5666105088file-title a, #ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 div.ygrps-yiv-640288664yiv5666105088file-title a:active, #ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 div.ygrps-yiv-640288664yiv5666105088file-title a:hover, #ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 div.ygrps-yiv-640288664yiv5666105088file-title a:visited { text-decoration:none;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 div.ygrps-yiv-640288664yiv5666105088photo-title a, #ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 div.ygrps-yiv-640288664yiv5666105088photo-title a:active, #ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 div.ygrps-yiv-640288664yiv5666105088photo-title a:hover, #ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 div.ygrps-yiv-640288664yiv5666105088photo-title a:visited { text-decoration:none;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 div#ygrps-yiv-640288664yiv5666105088ygrp-mlmsg #ygrps-yiv-640288664yiv5666105088ygrp-msg p a span.ygrps-yiv-640288664yiv5666105088yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 .ygrps-yiv-640288664yiv5666105088green { color:#628c2a;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 .ygrps-yiv-640288664yiv5666105088MsoNormal { margin:0 0 0 0;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 o { font-size:0;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088photos div { float:left;width:72px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088reco-category { font-size:77%;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088reco-desc { font-size:77%;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 .ygrps-yiv-640288664yiv5666105088replbq { margin:4px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mlmsg table { font-size:inherit;font:100%;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mlmsg select, #ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 input, #ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 textarea { font:99% Arial, Helvetica, clean, sans-serif;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mlmsg pre, #ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 code { font:115% monospace;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mlmsg * { line-height:1.22em;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-mlmsg #ygrps-yiv-640288664yiv5666105088logo { padding-bottom:10px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-msg p a { font-family:Verdana;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-msg p#ygrps-yiv-640288664yiv5666105088attach-count span { color:#1E66AE;font-weight:700;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-reco #ygrps-yiv-640288664yiv5666105088reco-head { color:#ff7900;font-weight:700;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-reco { margin-bottom:20px;padding:0px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-sponsor #ygrps-yiv-640288664yiv5666105088ov li a { font-size:130%;text-decoration:none;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-sponsor #ygrps-yiv-640288664yiv5666105088ov li { font-size:77%;list-style-type:square;padding:6px 0;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-sponsor #ygrps-yiv-640288664yiv5666105088ov ul { margin:0;padding:0 0 0 8px;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-text { font-family:Georgia;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-text p { margin:0 0 1em 0;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-text tt { font-size:120%;} ygrps-yiv-640288664 #ygrps-yiv-640288664yiv5666105088 #ygrps-yiv-640288664yiv5666105088ygrp-vital ul li:last-child { border-right:none !important;} ygrps-yiv-640288664
Yahoo Message Number: 159679
Your welcome Tobey And Thank You for the info that Vince gave. To me that was very helpful in the future.
Happy Trails Always Tobey !
Yahoo Message Number: 159633
Generally, you don't want to use 3M5200 on anything you might want to take apart in the future.
3M4200 might be the one to use if you might want to separate the things you used it on.
Check this site: http://sailanything.com/post/48445963210/4200-or-5200-what-should-you-use
RonC
2c Re: difference between "Dicor Self-Leveling Sealant" and "3M Marine
Mon Mar 28, 2016 1:00 pm (PDT) . Posted by:
Tobey,
Not sure about Dicor product but I’ve used 3M product successfully for our 2007 LD RB for resealing areas around windows, misc outlets, etc. I also used to seal up those thin stress cracks that appear on vertical corner pieces around the rv. Note: product has consistency of toothpaste when first applying it so pretty messy to work with.
John
Yahoo Message Number: 159669
I found your discussion with the factory about roof resealing to be interesting. I want to acknowledge that I don't have as much experience with motorhomes as others in this group. After reading various posts concerning roof seals, I decided that I should probably reseal the roof seams on our 2004 RK shortly after we acquired it four years ago. The original sealant appeared to be in good shape so I felt that a thorough cleaning, including some minor scraping and smoothing of high spots, would provide a good surface over which to apply Eternabond tape. I tested a short piece of the tape on some scrap aluminum and was pleased with the results. And yes, it would be very difficult to remove once applied. I was fairly confident that this would work well because the tape was wide enough to extend beyond the width of the sealant onto the metal roof surface. After carefully applying the EBond, I sealed the leading edges with a high quality polyurethane caulk.
Since applying the EBond, we have driven from NC to California and back four times as well as two trips into Canada. After each trip, I wash the LD, using soft brushes and a mop on the roof, after which I have inspected the EBond tape and found it to be in good condition. There are no signs that it is weakening or coming up and we have experienced no leaks. I am glad that I did not choose the option of removing the old sealant before applying the EBond tape. This seems to me to be along the lines of the old saying; "if it ain't broke, don't fix it". I did not try to fix it. I did try to "improve" it. I am happy with it so far. I thought that others might like to know how this worked out.
Jim NC, 04-26.5-RK
