Topic: How much danger in "a few frosty nights"? (Read 28 times) previous topic - next topic
Yahoo Message Number: 159408
Another question from a newbie: bought our 2002 LD 26.5' Mid-bath last month in Georgia. Due to time constraints, we did not have it winterized (emptied everything out, but did not blow out the lines or add antifreeze), so we stored in heated storage here in Illinois.
Here is my question: when will it be safe to bring it home and start prepping for adventures?
The extended forecast (as far as that is to be trusted!) for our area shows three nights in March with lows of 26-27 degrees. In April, it's expected to dip to 31 degrees three times before 4/10. The Farmer's Almanac cites the last frost date at 4/20. Whenever we bring it home, it will be stored on a driveway with access to electricity.
When we bought it, the person who did the inspection said he wouldn't worry about winterizing it, now that the most severe part of winter was over ("I wouldn't worry about a few frosty nights.") Very protective of our new-to-us LD, we put it in heated storage to be safe.
But now are very excited to bring it home and start prepping for our family adventures. What is the wise counsel here? Thanks in advance for your suggestions!
Re: How much danger in "a few frosty nights"?
Yahoo Message Number: 159409
This is based on a sample size of 1. Trip from Sacramento to Tucson end of January came back thru Las Vegas and Carson City Overniight temps last 4 nights were 52, 15, 21, 49. Interior temp never dropped below 48. Black And grey water tanks froze partly but thawed in a few days, dumped w/o problem.
If the holding taks are empty, they shouldn't be a problem. If you have electric access, a small heater and open cabinets should keep it above freezing.
Happy packing! YMMV Joel
dog Zeke
Yahoo Message Number: 159410
My guidance Is based on Information from this forum, the LD manual, and my experience this last winter. Dump the fresh water if not nearly full, dump gray and black tanks if not nearly full. Heat the hot water tank the night before or empty it.
Inside drape the front cab with a blanket, open all cabinet doors to include access door to the water pump, cup of RV anti freeze in the sinks, toilet, shower drain. Open all inside water faucets. Use a space heater. This might be over the top, but it took little time and I slept better.
Ed & Margee
Yahoo Message Number: 159414
Tobey, the best rule to follow for peace of mind is: if it's going to be below freezing during the night, you should somehow keep the interior of the LD heated. Exterior tanks, if not totally full can withstand some freezing nights if the day temps get above freezing. If you are "bringing it home", run an extension cord to the LD and keep a space heater on during the night and follow Ed's advice.
Chris (currently at Jalama Beach, CA)
Yahoo Message Number: 159426
Had our 2005 MB in VA several times in winter when temp dropped to about 20 every night. Coach internal temp maintained to about 65. No problems with internal plumbing, fresh water tank or holding tanks. Minor issue with dump valves; one of them froze. Thawed same with hair dryer. Later installed "electric heat strips" on the drain lines and valves. Plugged in the heaters if the temp was supposed to be below freezing. No more dump valve problems.
Doug
Yahoo Message Number: 159432
We live in Eugene Oregon. Brought our '92 midbath home in 1999. I have never winterized it. I drain the water and water heater and open all the faucets. While we usually have mild winters it has gotten down Into single digits a few times for a few days. One time my water filter failed and spewed water everywhere when I turned on the water pump! Otherwise no problems. The biggest problem is below freezing for extended periods. We have also camped in the snow without problems.
2004 MB
Yahoo Message Number: 159434
Last Jan thru March (2015) we spent winter in our '96 TK in Myrtle Beach SC. We were newbies, and had started full-time traveling late Sept 2014. It went down to 13°at night for several nights during Feb. From Vt, this was nothing. We disconnected the fresh water. Kept the hot water heater running, opened the under sink cupboard and the drawers. We ran the gas heater and a small electric heater. The indoor was kept at about 70°. We were fine but the toilet seat was FRIGID! Around us people wrapped everything with heating tape and insulation. Because they didn't disconnect the water hose at the faucet, the campground water pipe froze and split and they had to pay the repair bill (signs were posted in the campground).
All winter the windows except the back and side ones were insulated with that quilted foil, also the air conditioner,  swampcooler and fantastic fan. We put thick foam in the escape hatch and the bathroom vent. We were fine.
Hope this helps.
Art n Sandy KalleAnka '96 TK VT
Yahoo Message Number: 159440
We didn't do anything. We didn't disconnect them. We were clueless. In retrospect I wonder if the warmth from the sewer system helped. We had a Y connector then. Now we use a maserator.
Sandy
