Topic: Ford engine & chassis for LDs - I am looking for difference/importan (Read 43 times) previous topic - next topic
Yahoo Message Number: 158616
Thanks to Jeanne & Russ we saw a couple LD 26/5/27 MB this last weekend.
That is now our choice.
 Now, we would like to understand more about the chassis and engine/transmission/etc. - the things that can't easily be replaced (like fans or water pumps could). That will help us narrow down which years to be shopping for.
What we care about: We want to be able to climb over mountains, like the Rockys without struggling for long periods.  We have done the drop down to 45-50 because the vehicle couldn't do it, or could not get back up to speed after slowing down behind a slow truck.
So we want some power.
We are not sure what else we really care about, things that we can replace ourselves (water pump, fans, etc.), I am not so worried about.  But things that can't easily be replaced without ripping up walls... We just want to go in informed saying this is what is important to us and that we don't care about so much.
 Question 1:  From Andy's files, there was a change from a 4-speed transmission to a 5-speed one in the 2005 model.  From our readings that 5th speed makes a big difference in general for RVs.
Discussions here recently said there was a 6-speed transmission in the 2016 LD model.  Was that first introduced in 2016 or did it show before then (Andy's files stop at 2013).
 For those that have compared the 4-speed to the 5-speed to the 6-speed (ok, I know I am dreaming now), how much difference have you noticed?  Any info would be appreciated.  Also, I have seen references to half speed/gear increments.  Can anyone explain this?  (E.g. does that mean it is really 10 speeds not 5, or .....).
 Question 2:  2008 there is the new Ford 450 chassis.  More CCC, redesigned front suspension & steering, trouble-prone driveline/transmission parking brake eliminated, brake rotor increased from 10" to 13" in diameter, traction control added.
Now all this sounds fine, but for those who have compared the two, what difference have you really found to be important?
 Question 3:  Are there other big changes that are not so easy to upgrade over the various years of the 26.5/27 Mid Bath? Did tank sizes change? The web page says 27 midbath has 58 gal fresh, 35 grey, 28 black, 6 gal water heater, 14 gal propane tank.  But I understand that the web page might not be fully up to date.
Anything related to how it handles to drive it or .....
Thanks for the info, Jane.
Re: Ford engine & chassis for LDs - I am looking for difference/impo
Yahoo Message Number: 158617
"What we care about: We want to be able to climb over mountains, like the Rockys without struggling for long periods.  We have done the drop down to 45-50 because the vehicle couldn't do it, or could not get back up to speed after slowing down behind a slow trucK"
That will sometime happen, it's the nature of RVs and 11,000' of altitude.
They don't have the power to weight ratio that cars have and the elevation kills the power produced.
If you need big power, then a big inner-cooled, turbocharged diesel is what you want.
No LD will 'fly' over the Rockies, no matter what transmission you have, there is only 305-HP to push 14,000-lbs+.  Many small cars today produce more power.
You can get a small increase in power by installing a Bank's exhaust system, plan on spending $3000-4000.
I doubt if anyone here has driven a 2016 E450, with the 6-speed, so that question cannot be answered yet.
Having driven a lot of LDs over they years, I can't say I would go out of my way to get a 5-speed over a 4-speed. The extra gearing is at the lower end, increasing acceleration from 0-40 MPH but does nothing to help at cruising speeds, where an extra gear would be appreciated, especially when towing.
Same goes for the 2008, a good year but the changes are not immediately noticeable.
If I had my choice of used LDs, a 2008 model would be on the top of it, it was just before the cutbacks at Ford and LD and the following dark years.
Losing the ineffective driveshaft mounted parking brake is a good thing.
I don't believe the tank capacities have changed much on the MB for a long time.
Terry Tanner's Technoz site has many of the past yearly LD specification sheets, in the files.
https://groups.yahoo.com/neo/groups/Techsnoz/info It's members only site, so ask to join.
Happy hunting
Yahoo Message Number: 158618
Hello, I have the 2016 spec. in my hand (Were mailed last week).  In regards to Q3, the numbers are the same for tank sizes.
Yahoo Message Number: 158619
Thanks for the replies.
Larry, I left this out during my writeup, doing slow for a while (eg 15 minutes is fine and I wouldn't think twice about that), but doing a slow chug for an hour up the mountains with the engine loud and straining the entire time would try my patience.
 The people that said the 5th gear was a big deal had RVs like a 35-40' SOB, so possibly a different beast (with a 4 speed transmission they were struggling up what looked like a 15% grade with the engine loudly struggling).
Yahoo Message Number: 158620
If you are going to do a lot of mountain driving and don't like climbing the hill slowly with the trucks, I would highly recommend that you install a Banks Kit or equivalent.
 I owned a 2005 LD MB on a 2005 E-450 chassis. We always towed a Jeep that weighed about 4000 lbs.  I put a Banks Kit on the LD and it made a major difference in climbing hills.  You could "out climb" the trucks.  We took the coach over the Rockies at least 20 times during the period we owned it.  In normal driving on the level you don't even recognize that the kit is present.  I could see no difference in gas mileage with the Banks installed.  Others will tell you a different story on MPG.
 I now own an SOB on a 2013 E-450 chassis and do not have a Banks kit.  We still tow the Jeep.  The coach weighs almost the same as did the LD.  I have taken this coach over the Rockies (I-80 & I-70) 5 times and really missed the extra boost provided by the Banks Kit.
 Be aware that the term "Banks Kit" covers a lot of different sets of hardware.  Banks keeps redesigning their products to match the latest changes in the Ford engine.  For example Banks made very significant changes in the kit between for 2005.  The 2005 kit did not look the same or work the same as kits from previous years.  I have not kept up with all the recent changes to the kit, but there have been quite a few.  Vehicle performance with the kit installed will differ from year to year.
 Also be aware that there are other performance enhancement components that can be installed on a coach that provide the benefits of the Banks Kit, perhaps at lower cost.  Basically these are exhaust headers and larger exhaust system.  To consider this option you need to locate a "dynamometer shop" that does RV work.
Doug Baker
Yahoo Message Number: 158623
Hey Doug,
Question for you. IF the Banks system is so great, why haven't you had it installed on your newest Class C?
Steve K
Steve K
2003 Mid-bath
Yahoo Message Number: 158646
Just to provide a counterpoint to Doug's experience with the Banks upgrade: I had a full Banks Powerpack upgrade--"the works"--done on my 2003 Lazy Daze midbath a few years ago. As others have said, it cost three or four thousand bucks. I noticed very little difference in acceleration or hill-climbing ability afterward.
I still have to slow down to 35 mph or less on some of the steeper upgrades in the Rockies. (My rig is loaded close to the 14,050-pound maximum, and is towing a 3,800-pound Subaru Forester.) For me, that money would have been better spent elsewhere.
I feel much better about the $1,879 transmission upgrade/rebuild and larger tranny cooler I had installed by John Wood last year. Those didn't get me any more speed, but my transmission now runs much cooler when climbing steep hills, and has substantially beefed-up parts in critical areas.
Yahoo Message Number: 158653
Because the coach will probably have a "limited life" with me and I felt that I could endure a few slow uphill trips.  At the moment I am trying to determine how long I will keep this coach as I am not happy with its "road manners."
 There are no Banks "installing distributors" in my area so I took my LD to Banks Engineering in Azusa, CA (about 100 miles away) to get the kit installed.  Banks is located on a dead end street in a semi-industrial area.  Is very crowded so getting into and out of the Banks facility is a pain.  It takes Banks about 10 hours to do an installation so I towed my Jeep to Azusa, left the coach and drove the Jeep home.  Went back 2 days later to get the coach.  I really didn't  want to do this again as my current coach is longer and would be harder to maneuver at Banks.
 Overall I was pleased with the Banks Kit, but I felt that it was a little pricey;  almost $4K.  If I decide to do anything with this coach it will be with alternate components rather than a Banks Kit.  I have a good "dynamometer shop" nearby that does "RV performance work" and installs exhaust headers, larger exhaust systems, etc.  Once upon a time they were an installing distributor for Banks, but gave it up.  I know that they have modified a number of the older Banks Kits (pre-2005) to use newer software which is better than the previous stuff.
Doug Baker
Yahoo Message Number: 158655
Hey Doug,
Thanks for the candid reply about why you haven't had the Banks upgrade installed on your newest rig.
While I haven't towed anything behind our LD, I haven't seen a need for more power. Like you, we've climbed over the Rockies numerous times.
We were fairly certain that we would put a lot of miles on our rig and I wouldn't want to do *anything* that could stress the engine or transmission. Even as I've looked for a gently used rig, if I see it has a Banks system installed, I shy away from it. Just my $.02.
Always informative to read your posts, so thanks again.
Steve K.
Steve K
2003 Mid-bath
Yahoo Message Number: 158658
For my $0.02, I would go with a trans mod anytime. I have the old E4OD, in which I have only slight confidence. Thanks for that link Andy, I copied it into my Wish List.
Coming from a Powerstroke 6.0 tow vehicle, and based on secondhand knowledge, I am leery of engine mods other than running more air into and out of them. Banks users I know have had great, and disastrous results. Speed on the mountains is the least of my worries when running any vehicle close to its GVWR. That said, I found a lot of benefit to improved breathing smartly applied to work vehicles like my old 460 and 6.0
Paul
'92 Mid Bath
Yahoo Message Number: 158663
"Banks users I know have had great, and disastrous results.'"
Over the years, there have been several reports of Bank's computer add-on chips failing, leaving the LD stranded until the add-on chip was removed and the original parts replaced.. One of breakdown left the LD stranded deep in Mexico. Think about that for a while if you travel to remote places..
Anything that decrease reliability is off my "must have" list.  I hate on-the-road breakdowns and will go along ways to prevent them.
The early 265-HP V-10 LDs, will get significant results from the Banks exhaust system. Ford incorporated much of the same design in the later 305-HP V-10s.
If my LD was equipped with the full Banks system, I would find out how to removed the add-on chip, document it and store the instructions in the LD so I or a mechanic would have clue on where to begin the repair.
Except for cooling upgrades, leaving the LD's driveline stock will provide the best chance for a long, trouble-free life and more fun times on the road.
Getting there a few minutes earlier doesn't really matter that much in the cosmic scheme of things IMO.
Yahoo Message Number: 158667
Thanks for the info.
 Larry, ok I admit engines are not my forte (since I remodel houses I will be the chassis person, hubby will be the engine person), what do you mean when you say
Except  for cooling upgrades...
 I understand the general concept, but what are the cooling upgrades people put on their LDs.
Jane
Yahoo Message Number: 158668
I appreciate the info on the Banks. We like reliability, a reason LD was attractive to us, and plan to be in out of the way spots most of the time, so we would probably pass on the Banks.
 Andy, so the John Wood upgrade/rebuild... would you do that only to an ailing transmission or would you do that to a perfectly good but 4-speed transmission?
Larry, what are the cooling upgrades you speak of?
Yahoo Message Number: 158669
Hi Larry,
 I agree with your assessment of things.  However, things are not completely black & white;  it depends on the vintage of the coach and the Banks Kit.
 Prior to 2005 the Ford E-450 had an Engine Control Unit called the EEC (Electronic Engine Control).  If I recall correctly there was a separate electronic control unit for the transmission.  The EEC had been around since the 1970's.  The computer was developed by and manufactured for Ford by Toshiba.  The instruction set for the computer was a stripped down version of the Digital Equipment Corp PDP-11, a 12-bit machine.  The Toshiba IC that was  used in the box was never made available to the public.  Over the years there were many versions of the EEC.  I think that the last was EEC-VI.  The EEC had a slot in one side where you could plug in a circuit board and this is what Banks did.  The Banks Kit included a "programmer box" that plugged into the board or computer and changed a lot of parameters in the EEC software.
 For the 2005 E-450, Ford replaced the EEC with a new computer unit referred to as the Powertrain Control Module because is managed both the engine and transmission.  This box was developed for Ford by Ford's equivalent of Delco.  The PCM had no slot for plugging in a circuit board.  The software for the PCM was much different than in the EEC.  It incorporated a lot of the stuff that the Banks Kit had previously provided.  Obviously Banks had to redesign the Banks Kit.  The kit no longer had a plug in module but still had the headers, exhaust system and K & N air filter.  It also had a programmer box but it only changed one parameter in the PCM;  it extended the time delay before allowing the engine to switch from "open loop" to "closed loop."  This was to give the O2 sensors more time to warm up.  The Banks Kit moved the O2 sensors a little further from the engine.  That and the higher air flow through the headers caused the O2 sensors to warm up more slowly.
 The Banks Kit with the plugin circuit board certainly caused a lot of coaches to get stranded.  In fact a company has taken the software from the PCM and reworked it to run in the older EEC units and it will do it without the plugin circuit board.  I know that the Dyno Shop, which is near me, has done this to a number of coaches that have the older Banks Kit.  I had my LD in their shop at one time to have it and the Banks Kit checked out.  I probably would never install another Banks Kit, but might have these guys install headers and a larger exhaust system.  I haven't looked in detail at the current Banks Kit, but their model numbering system indicates that it is little different than the kit in 2005.
 I suspect that I have made more than a few mistakes in the above facts.  I am doing it from memory as I no longer have my manuals and notes on the subject; they went with my LD.
Doug Baker
Yahoo Message Number: 158670
Doug there is some issues with you concept. It starts wilt calling the PDP 11 a 12 bit machine. It was a 16 bit machine from day one.
https://en.wikipedia.org/wiki/PDP-11
I worked with well over a hundred various PDP-11's along with several of the earlier and overlapping PDP-8's. Now the PDP-8 was a 12 bit machine..
https://en.wikipedia.org/wiki/PDP-8
If the early ECU's were based on the Dec machines PDP 8 that would be interesting.  I'd like some more history if you have any sources..
Yahoo Message Number: 158671
I have the 265HP V-10 built in 1997. I installed a set of Banks headers myself and their chip, plus an AFE Air Intake system. I had a local exhaust shop install a much less restrictive but quiet muffler with 3 inch piping throughout.  It helped a LOT. I figure I am near the 305HP motors as far as horsepower and torque. Knock on wood, but no problems so far after 60K miles.
 If I could recommend anything, install sufficient gauging for oil and/or water temperatures and pressures. Get a ScanGage too.
Chuck Myers 97RB @Hartford IA
1997 RB
Re: Old computer programmers ;>}
Yahoo Message Number: 158673
Yep, I caught that as well.  Doug was most likely thinking of the PDP-8.  In my early career, I spent a lot of time toggling machine code instructions in via the switches on the front panel of PDP-11s.  I had memorized most of the primary instruction set.  I remember the PDP-11 instruction set as well designed and powerful.
By the time we moved on to the VAX computer series, I pretty much relied on assembler and C coding.
Enough off topic reminiscing, Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Yahoo Message Number: 158676
"Except for cooling upgrades...
I understand the general concept, but what are the cooling upgrades people put on their LDs."
Jane
The engine's cooling system is well designed and rarely has problems as long as it is properly maintained.
There isn't much that can be done to improve it.  In the past I have posted several articles on maintaining the cooling system and the fixes for the problems I have observed. You can use the search function to find them.
The transmission tends to run warm when towing in the summer and climbing long, steep grades.
So, the largest transmission cooler that would fit in our E450 LD was installed. It has twice the cooling surface area of the stock Ford cooler.
https://www.flickr.com/photos/lwade/sets/72157651573514141/with/15366063270/
The new cooler has twice the cooling surface area of the original and does a good job of dropping the temps by a good 10-15 degrees on a hot day. Well recommended for towing in hot climates.
The cooler is shoe-horned in and it's installation is a involved project that require a bit of disassembly and modifications to some existing brackets. It took several hours to install and was well worth the time.
Yahoo Message Number: 158677
Doug
There has been multiple version of the Banks system, as the emission regulations and engines changed. I have seen several variations through the years but do not know the year to year changes. The degree of power increase is also dependent on the model year.
From my point of view, more dependability and zero extra costs are nice benefits to not having the system.
Now I wouldn't mind just running a stand alone exhaust system, if there was much power to be gained.
I do not like messing with the Factory electronics in any vehicle.
Ford, like the other manufacturers, has spent hundred of millions of dollars designing the various systems to be dependable. No after-market company, even Banks, has the same resources or can do the the amount of testing that the OEMs do before releasing new a product for sale. Plus, when major problems do occur, the OEMs will many times fix the problem through TBSs and recalls.
My point was if you run a Banks, that uses add on electronics, you are risking a much greater chance of a breakdown. The Ford factory electronics are very dependable and breakdowns are rare.
The Banks electronics have not shown the same dependability. One breakdown in the middle nowhere erases all the positive parts of this addition. If one has a Banks system, learning how to reset the computer to stock would be good thing know.
Yahoo Message Number: 158679
A less restrictive exhaust system is tempting, as mentioned, but the result could well be more engine/exhaust noise.   You won't know if this is an issue for you until after the the install.   Something to keep in mind.   Frank
plan B - 2023 Travato
Yahoo Message Number: 158680
"If I could recommend anything, install sufficient gauging for oil and/or water temperatures and pressures. Get a ScanGage too."
Chuck
As you found out, the 265-HP V-10s really benefit from the Banks system.
The E450's dash has coolant temperature and oil pressure gauges but lacks the important to know transmission temperature gauge. Useful information to know when towing.
The dash does have a transmission overheat warning light but it comes on at a very high temperature, I have not seen or heard of one illuminating. I'm not sure if the earlier 4L100s had this feature.
The later 4L100 4-speed transmissions (starting around 2002) include an internal oil temperature sender, unlike the older models. The temperature sender is needed to use a ScanGauge .
Earlier LDs, without the temp sender can use an aftermarket gauge, with the temperature sender installed the transmission's oil pan or in one of the transmission's oil coolers supply lines.
Yahoo Message Number: 158687
I am thinking about flashing the stock Ford computer to optimize the fuel curves. Same stock hardware and can be flashed back to stock using a SCT 5 star tune. 5 star tunes also run a very safe fuel strategy and compensates for 10% ethanol, which Ford did not in factory form until model years 2011, which aids in making the truck run correctly.  In a nut shell the 2v V10 needs the open loop strategies enabled so not to run in closed loop at WOT causing a lean condition over mountain passes. The later 2v V10 pi head makes more hp but at a higher rpm range where the earlier one will produce more torque at lower rpm. I was really planning on swapping to a pi head when rebuilding but with all of the tuned torque curves I have looked at I will just stay with the non pi head.
On my 97 I use Torque on my android phone or tablet to monitor transmission temps with a obdii elm bluetooth adapter. I was able to set audible alarms for when the transmission reaches 190 so I can back off and monitor temps more closely.
My main reason for the banks upgrade were broken exhaust studs... And since everything was already apart.... And I told my DW we could always put them on our next LD.
-Craig 97TK
1997 TK
Yahoo Message Number: 158698
Several of you caught my error about the PDP-11.  However, as I said, I was doing it from memory and the memory is not always reliable any more.  I guess that it was the PDP-8.  I should have known better as I was a long time DEC customer; initially purchasing two of Ken's earliest PDP-1's
 I do not know all the changes that the Banks Kits have undergone, but I am certain that there were many.  If you look at the CARB (CA  Air Resources Board) web site you find many Executive Orders for Banks Kits and the various components.   (The CARB EO's are the thing that allows their products to be used in CA.)  As Ford made minor tweaks to the V-10, Banks was forced to make tweaks to their products to maintain compatibility.  They made a lot of tweaks to the mechanical configuration of the headers.  The headers that were on my 2005 would not fit on a 2004.
 The results that you obtained from installing a Banks Kit varied greatly from year to year; despite their consistent claims about increased power and better gas mileage.  The year 2005 was not a good year; maybe because the changes made by Ford and Banks were so significant.  Another fact about Banks Engineering is that they market "kits" but they really engineer and build components like headers, cat-back exhaust systems, etc.  You do not find "kits" in their warehouse;  you find only the individual components.  When someone orders a "kit" a clerk runs through the warehouse with a "pick list" and a box basically assembling the kit.  The same thing happens when you take a vehicle there to have a kit installed.  In my case they installed the wrong CARB sticker on my coach so I could not get a smog test done.  In addition my coach was having a "fuel flow" issue and the Ford technicians blamed it all on the Banks Kit.  I spent many hours in Azusa with the engineers at Banks, being educated and getting things squared away.  Learned a lot and was assured that there was no way that the kit could cause my fuel flow problem.   Fuel problem eventually turned out to be a failing fuel pump which the Ford technicians could not diagnose.  That summer while climbing the eastern slope of the Rockies, headed for Cheyenne on I-80, the cause of the problem became very evident.
Doug Baker
Yahoo Message Number: 158759
"Andy, so the John Wood upgrade/rebuild... would you do that only to an ailing transmission or would you do that to a perfectly good but 4-speed transmission?"
I did it to a "perfectly good" 2003-vintage Ford transmission. "Perfectly good" in this case means "built by Ford as cheaply as possible." John Wood replaced a number of cheap, stamped-metal transmission parts with forged and machined parts that he has specially made. And he replaced the transmission cooler with one that is about half again as large. The result: coolant temperatures run three or four degrees higher on steep slopes, but transmission temperatures are ten or fifteen degrees lower. To me that's a good trade-off, since the engine's cooling system has several ways of actively regulating its temperature (thermostat, etc.), which the transmission has none.
A friend had the same upgrades done by Woods to a '98 E350 chassis, and was equally impressed by the quality of the work and the results. In that case the transmission had been making a ticking sound, but another shop had assured my friend that it was common for Ford transmissions to do that. When John Wood disassembled the transmission, he found a badly distorted "spring ring" that would have stopped the transmission dead if it had gotten just a hair more bent. He replaced it and other parts with beefed-up ones.
Reply #24
Yahoo Message Number: 158766
That's good information Andy. A friend of mine just spent a week in western Washinton while his W4OD was rebuilt. A plastic (!) spring the size of that in a ball point pen was cited as the cause of the failure. This information on John Wood is now includes in my "wish list", to be done when we are convinced our coach is going to be a long term RV. Thanks again.
Paul
'92 Mid Bath
