Topic: Lens cover and paralastic (Read 12 times) previous topic - next topic
Yahoo Message Number: 158452
Hey does any one know where to find a replacement lens for the Amber 1.5 in diameter running light on the front of the cab over?  Also been doing some searching on the forum just want to be sure I can use paralastic sealant for touching up areas around end caps and Windows?
Thanks
Kevin
1998 26.5 RB
Re: Lens cover and paralastic
Yahoo Message Number: 158453
Kevin-
 When I had to replace the front caps in 2013 the factory sold me (along with the caps) several tubes of Loctite PL S40 caulk to use as the sealant. This may be what they are recommending today; you could call them and ask. I ended up buying mine from the local hardware store, because what I got from the factory was a bit "stale" and therefore hard to apply and smooth.
Former owner, 1997-8 mid-bath
Yahoo Message Number: 158455
You can find lens replacements (and a lot of other light-related items) on the Bargman site:
Welcome to Bargman Lights
And, many of us have successfully used 3M 5200 "Fast Cure" to seal around windows, end caps, etc. (You may find it at Home Depot, but AFAIK, it's available there only in the 3 oz. tube.)
Note that the product comes in different sizes; it does cure quickly and the unused portion stiffens in the tube, so buy the appropriate size. Thorough cleaning and surface prep are critical, and masking off the area to be sealed will produce a neater job.
3M Marine Adhesive Sealant 5200 Fast Cure White, 06535, 1 oz tube (Pack of 1): Automotive Adhesives And Sealants: Amazon.com:
Yahoo Message Number: 158461
Yes about any camper place,  I bought one here in phoenix at orangewood but im sure any parts place or camper place will have it. good luck grumpy
Yahoo Message Number: 158466
I just replaced a couple originals with the exact same unit, a Peterson light, which I found at the first place I looked, my local auto parts store.  These are common lights for trailers. I used Big Stretch sealant because I had some left over from another job, and bought it based on recommendations here or at the Lazy Daze Companion.  The sealant seals and compliments the two screws that hold in the lights.
Paul
'92 Mid Bath
Yahoo Message Number: 158604
So I found some replacement peterson lights at finditparts.com I am going to replace the whole assembly on a few of them because the bulb holder is just worn out.  So should I use big stretch to seal the screws and wires to prevent moisture.
