Topic: TV suggestions?? (Read 13 times) previous topic - next topic
TV suggestions??
Yahoo Message Number: 158036
I'm considering a TV for our 1995 TK.
It will use the antennae built on to the RV or something better? I'm looking for TV brand and type suggestions. Again I'll have no satellite.
Thanks.
Re: TV suggestions??
Yahoo Message Number: 158047
The wiring put in by LD is for a 12v TV, so your path will probably be easier with a 12v TV.  Jensen is the make that came with my RV.  Mine is now entering its 8th year of trouble-free use.  I do know of someone who had trouble with their Jensen and had to replace it.  Personally, if mine died I would start my search with Jensen TV's.
 As to antennas, TV antenna technology has changed since your RV was built.  In general, assuming you have the kind of antenna mount that I have, you will want a directional antenna feeding into a booster or amplifier.  Again, you will want a 12v amplifier.  Were I you, I think I would contact the factory to ask what they are now using.  I would then contact that manufacturer and ask what they recommend for your specific use, in terms of combination of antenna and amplifier.
Ken F in NM
Yahoo Message Number: 158048
The 2015 TV is by Jensen.
JE2412LED. 12v.
The amp and antenna are both by Winegard.
At least in my TK.
Ed
