looking for help with fuses January 06, 2016, 03:53:31 pm Yahoo Message Number: 157962I recently bought a 1992 26.5 MB. Putting it back into perfect order is a long term project, but I am stumped now. The windshield washers don't spray, and I don't want to go on the road without washers if I can help it.The lines are clear, the pump runs if wired to 12v, but there is no current to the wires going into the pump, so I have an electric issue somewhere upstream. Hopefully it is a fuse. No manual accompanied my LD though. I have tried to find a bad fuse, but all are good. Maybe I missed one. Could someone with a '92 manual tell me: - Is the washer and wiper on the same fuse? (My wipers work, so if they use the same fuse, that is not my problem. - What number/position is the washer fuse?If not a fuse, I will start at the switch on the stalk and work from there.Thanks for the help! Paul
Re: looking for help with fuses Reply #1 – January 06, 2016, 05:47:30 pm Yahoo Message Number: 157965I'd guess those fuses are in the engine bay. Have you looked at those?EdFort Worth
Re: looking for help with fuses Reply #2 – January 06, 2016, 06:11:37 pm Yahoo Message Number: 157967No, I checked those next to the steering column. I will get into the power box in the engine compartment next. One thing led to another, and I spent most of the day cleaning the engine and the cowl area. Thanks!
Re: looking for help with fuses Reply #3 – January 06, 2016, 08:20:22 pm Yahoo Message Number: 157970You can usually download an owners manual online for the vehicle. If not I am sure you can find dine for either a e150,250,350. The electrical is usually clase enough that any of these would identify the fuse circuits. The cutaway is real close to a regular van in many ways..This should be your fuse layout.. but no guarantees.. http://ww2.justanswer.com/uploads/fordguy4u/2010-05-18_200919_A1.pdfGood Luck Garry
Re: looking for help with fuses Reply #4 – January 06, 2016, 08:25:37 pm Yahoo Message Number: 157972And the windshield wiper circuit..http://ww2.justanswer.com/uploads/fordguy4u/2010-05-18_203317_A1.pdfHope this helps..By the way these sites can be great or worthless depending on the expert you get..http://www.justanswer.com/ford
Re: looking for help with fuses Reply #5 – January 06, 2016, 09:16:02 pm Yahoo Message Number: 157973Thanks Garry, this is exactly what I was looking for- I was not looking for a breaker, so tomorrow I'll give it a look-see.
Re: looking for help with fuses Reply #6 – January 06, 2016, 09:50:54 pm Yahoo Message Number: 157975I was able to download a 1996 Owners manual, which is the oldest Ford has digitized. But with that and the Haynes book and help from people here, I can piece it together.
Re: looking for help with fuses Reply #7 – January 06, 2016, 09:56:11 pm Yahoo Message Number: 157976I sure hope you can chase this down and find a solution. Please post your outcome.Ed & Margee Fort Worth
Re: looking for help with fuses Reply #8 – January 10, 2016, 02:27:00 am Yahoo Message Number: 158016I am making progress. On Garry's advice I signed up to JustAsk.com, and got good support. I found an eliminated the washer module as a culprit, so it looks like I need a new multi switch- the stalk on the steering column. About $52 part, and fairly easy to replace.
Re: looking for help with fuses Reply #9 – January 20, 2016, 01:13:20 pm Yahoo Message Number: 158225Conclusion- Ed and Margee you asked to read the outcome-The wiper switch was not the issue, so now I have a spare turn signal/wiper stalk switch. I put the new one in, reserved the original.The advise I got about testing the circuit from Just Ask was undoubtedly correct, but though I can do many things, electric is the flat spot on my wheel. So I went into "parts replacement" mode.The only other part in the system for a '92 is a module unit under the passenger dash board. I was very lucky to find one that fit on Ebay for a very good price. Once it arrived and I plugged it in, all wiper functions returned to normal.Thanks to everyone for support!
Re: looking for help with fuses Reply #10 – January 21, 2016, 11:10:25 pm Yahoo Message Number: 158270Well done Paul. It sounds like you scored on this issue and more importantly, it didn't make an old man out of you. I'm working on a plumbing problem for my daughter and it has caused me to speak in tongues! Take care and thank you for the follow-up.Ed & Margee Fort Worth
