Topic: Air Compressor Recommendation (Read 52 times) previous topic - next topic
Yahoo Message Number: 157133
I need a air compressor to take with us that will air the tires. I bought a Campbell-Hausfeld 1 Gal. that I am returning because it doesn't do the job. What do others take with them? Thanks John in OR.
John in Bend, OR
Re: Air Compressor Recommendation
Yahoo Message Number: 157135
John, I use an air pump instead of an air compressor. It's made by Husky and cost me around $30.00. I plug into external outlet in frig compartment, fire up generator, and have at it if I'm boondocking. I have filled inflatable boats like the Zodiac for folks when there foot operated pump failed. There is no room for a compressor tank in my storage compartments and the air pump works fine. Just carry a good extension cord with it. I use one with 8 gauge wire.
http://www.homedepot.com/p/Husky-120-Volt-Inflator-HY120/202871788
bobmoore14
Yahoo Message Number: 157159
John, I bought a VIAIR portable compressor that runs off of 12V DC. You have to hook it directly to the chassis battery with the included clamps and should have the engine running when using it.  I bought the 400P-RV model which comes with two air hoses which, when connected, allow me to each all the way to the back axle of my toad. It is a little pricey at $240 on Amazon, but there are less expensive models with fewer accessories. It is a tankless compressor, so it is very compact. I was surprised at how quiet it is. I have been very pleased with it so far (about 9 months).
randyjanne
Randy
Captain of The Wanderer
2005 RB
Yahoo Message Number: 157165
The air compressor thread comes up periodically; if you use the "Search Conversations" box at the top of the message board's home page, quite a few posts on this topic will show up.
You might also look at this website; it has a lot of choices:
http://www.aircompressorsdirect.com/
Yahoo Message Number: 157166
How do you connect the hose to your rear tires? I have standard valve stems, and I'd need a dually tire chuck to reach them.
Eric Greenwell
  [lifewithalazydazerv] wrote on 11/23/2015 11:54 AM:
2005 Jayco 24SS
Yahoo Message Number: 157172
"How do you connect the hose to your rear tires? I have standard valve stems, and I'd need a dually tire chuck to reach them."
As others have said, long metal tire stems from either Chuck "The Tireman" Carvitto or Borg solve this problem inexpensively, and are highly recommended.
Yahoo Message Number: 157173
OK, I gotta learn not to respond before reading ALL the messages. Sorry for the duplicated information.
Yahoo Message Number: 157192
Thanks, too!...I need same...will follow you example....you, Joan & many other great folks are appreciated.
Best, Vaughn
Yahoo Message Number: 157203
Another great product is 12v compressor for tire inflation from Slime.
 Odd name but works like a charm and less than $100. I used to fill tires up to 100 psi. Check out on Amz.com.
John
Yahoo Message Number: 157206
--- There are quite a few Slime 12V compressors (in the Automotive section) on Amazon; can you specify the model that you have?
Yahoo Message Number: 157213
Hi Joan,
 Mine is a few years old but I believe it's Slime 40026 2X HD model at $69.42 on AMZ.Com.
 Should reach about 30'. Need decent access to valve stem as it's a screw on type connection. Works great and priced right.
Good luck.
John
Yahoo Message Number: 157270
bobmoore14
Please note that this 120 volt inflator is on sale at Home Depot for $14.98.  I bought one and will test it in a day or so as a means of "topping off" our car and LD tires.  Thanks to Bob for his advice on this inflator.
Ed & Margee Fort Worth
Yahoo Message Number: 157272
I just completed a test of the above inflator (Husky 120V Inflator) on our two (2) cars.  All I can say is it worked just fine, it was quiet and easy to connect to the valves.  The small PSI gauge on the Husky was accurate to within 2-3 lbs according to my best tire gauge.  As most would expect, it ain't fast but fast enough since I'm not racing NASCAR.  I plan to test this inflator next week on the LD.
Yahoo Message Number: 157273
Ed, That's what I have used for 4 years on my LD tires since my 12VDC pump units burned up. The Husky unit fits in outside storage no problem.
Your right it's not fast but it gets the job done, fairly compact, low cost, and seems to be a reliable unit. I can pump my rear tires to 65 PSI. You just have to be patient. If unit is run for more that 5 min.s or so I stop and let it cool for awhile. Being retired I am not in a hurry for anything, quarter mile/racing in Jeep being the only exception.
bobmoore14
Remembering Peltier
Was he was guilty, or set up?
Yahoo Message Number: 157280
While I have carried a small 12-volt compressor for decades, I can't remember when it was last used to fill one of our tires.
Good tires leak very little. Ours Michelins get topped off two or three times a year, always at home or somewhere where compressed air is available.
We let the TPMS system do the checking for proper pressure, reducing a major cause of lost air.
Point is that some are way overthinking this and buying large, heavy compressors, with excessive capacities, when a small compressor will do the same job (in a little longer time).
If a small compressor cannot keep up with a leak, it's time to install the spare and to get the leaking tire repaired or replaced IMO.
Most would be better served buying a small compressor and investing the rest in a TPMS.
Surveying Morro Bay in preparation for the 2016 Yahoo West GTG.
Yup, not much has changed in thirty years, except the food is better.
Yahoo Message Number: 157286
I'll repeat what I've posted before - a good standing bike tire pump will work just fine, while providing some aerobic workout. Takes up little room and is always available wherever you need it, even for the bikes.
Yahoo Message Number: 157295
aq433 may have suggested a nice solution for a young flat-belly.  However, if I suggested to DW that we should use a bike tire pump to top off the tires as needed, she'd advise me otherwise.  How do I know that ... let's just say I've learn a few things about marriage and one of them is what not to say!  LOL
Yahoo Message Number: 157315
I have done this and have zero desire to repeat! Garry
Many years ago I enticed my children & their neighborhood playmates to do most of the digging for a smallish backyard fish pond (rather like Tom Sawyer's fence painting enterprise).  I don't think there's enough room in LDy Lulubelle to haul enough kids--& I no longer have access to enough kids--to make a bicycle pump a viable option at this point in my life...anyway, the bicycle pump found its way to the ditch at the farm.  ...now if there were a way to harness the 4-Legged Alarm's energy when she sees a squirrel, that might be another story, but the 12 volt or 110 options seem better for me.
Lynne LDy Lulubelle, '05 30' TB Lilly, 4-Legged Alarm
Lynne
Lilly, the 4-Legged Alarm
Yahoo Message Number: 157316
So anyway, I was at Home Depot today when what should I behold but a large display rack of Ryobi air (pumps?) for $24.88 with an 18 volt Lithium battery and the size of a cordless drill. Said it would supply up to 150psi, no mention of cfm, or cfd for that matter. Interesting. Might have time for a cup of coffee and a short snooze to get another 2psi into a tire.
Any available knowledge on these critters?
Ian
2015 MB
Yahoo Message Number: 157328
"Ryobi air (pumps?) for $24.88 with an 18 volt Lithium battery and the size of a cordless drill."
I have a fair-sized collection of Ryobi One+ 18V power tools and like them a lot. I've built a lot of projects with the drill, saber saw, circular saw and sander, and I use the vacuum every day.
Based on my experience with the Ryobi tools and with small air pumps, I'm a little skeptical that the battery in the pump you mentioned will last long enough to fill a flat RV tire. But it would probably be adequate for topping off one that was a few pounds low, and that may be all that's needed.
And at $24.88, the bundle you mentioned is probably worth buying for the battery alone. :-)
One thing to keep in mind: you will need a charger if the air pump bundle doesn't include one. Home Depot generally seems to carry only Ryobi's 120 VAC charger, but there is a version that can also run on 12 VDC, and that's the one I'd buy.
Reply #24
Yahoo Message Number: 157329
Quick correction: the Ryobi charger I mentioned in my last post only runs on 12 VDC, not 120 VAC. For a full-timer like me, that's ideal, but if you do most of your work in a fixed-location home, you may prefer the 120 VAC version.
