Topic: Toilet in Mid Bath (Read 12 times) previous topic - next topic
Toilet in Mid Bath
Yahoo Message Number: 157092
Hi Melinda. I think the seal that Ken mentioned should have been nine  inches in circumference, not diameter, if they seal the "white flush dome". That  dome is a valve, operated to open the entrance into the black plumbing tube(s)  leading to the blackwater holding tank. My TK has the toilet lead directly into  the tank, but it seems that most motorhomes and trailers have the tank some  distance away. The black rubber seal at the base of the toilet against the  floor is about 9 inches in diameter.
If the opening at the base of the toilet bowl isn't white  plastic, then maybe the return spring didn't return the valve to closed. I  haven't looked at this part since mine is still working. Hope this helped.  RonB in San Diego.
