Topic: Toilet in mid-bath (Read 30 times) previous topic - next topic
Toilet in mid-bath
Yahoo Message Number: 157073
Something has happened, but don't know if I have a disaster in the making or a problem that I just don't know the solution for.  In my 2011 Mid bath, it has always had the two drains/bi-value (what is the term I am looking for? ? ? ? ) right below the ring. Now I have one.
Last night, it sounded like water was backing up in my black tank (tank was emptied on Tuesday), so I let water back up to see what happened. Sure enough, but it then "flushed" without me doing anything else. That is when I noticed the bivalve or whatever it is called had disappeared. Now it drops down about 8-12" before curving to the right.  I do not see any separation, leaks.
Has the shroud dropped off, obviously the duo valves/drains have dropped into the tank.. funny, I just can't remember what is normally there and of course, I am not familiar with the terminology... can anyone guide me on this one?
Melinda 2011 27' MB
2011 Mid Bath
Re: Toilet in mid-bath
Yahoo Message Number: 157075
I don't have my toilet manual with me so I'm talking off the top of my head.  I don't think you have a disaster in the making, just a broken or stuck toilet valve.  Has the value become stuck in the open position out of sight?  If the valve actually come loose and fell into the black tank, that might be a bit of challenge.  I'm hopeful that the toilet design is such that the valve can't come loose.  So just inspect the opening closely for a stuck open value.
Ed & Margee Fort Worth
Yahoo Message Number: 157076
After R&R my toilet 3 times to fix a leak that was a bad vacuum breaker, I would pay an RV shop to do it next time. Not fun. If the Sealand unit breaks again I will replace it with a Thetford. It sounds like your toilet is going to need surgery to repair, which usually means removing it. I would shop for a qualified RV shop to resolve. When I had issues I called Sealand and they overnighted the parts I needed directly to me. They can tell you the closest qualified dealer.
bobmoore14
Yahoo Message Number: 157079
A couple of photos may help us figure out what your problem is and to find a solution or cure.
BTW, Mid-baths have two holding tank drain valves, one for each tank.
Yahoo Message Number: 157080
Melinda, you lost me.  I don't know what you are describing as once having had two, now having one.  Let me walk you through the terms and components.
 Inside the bowl, looking straight down, the bowl should end in an opening about 3" in diameter.  In that opening should be a black ring formed by one of the two neoprene seals.  These seals are about 9" in diameter and are stacked, one above the other, forming a seal between the toilet bowl and the mounting pedestal and flush dome.
 The mounting pedestal is a black plastic component that is mounted between the raised platform and the base of the toilet.  It holds two external components - the flush pedal, to the left looking at the toilet, and the water connection lines.  The flush pedal operates a valve that puts water into the bowl and the hand-held flush wand.  When the pedal is pushed down, the valve allows water to flow up two hoses.  One plugs into the back of the toilet by a friction fit and directs rinse water to the sides around the toilet bowl.  The other directs water to the hand held spray for manual rinsing.
 The mounting pedestal is connected to the toilet by several pieces of equipment.  The outermost is a trim piece of thin beige plastic that splits in two at the flush valve, allowing its removal.  It comes out as one piece.  Below the trim cover is a stainless steel band clamp with a nut that tightens and loosens it located at the back of the toilet.  The band clamp sits in a shallow groove about half an inch wide on a heavy plastic ring.  That ring is in two pieces.  It locks the toilet to the pedestal base, and when the clamp is removed, it comes out in two pieces.
 The only other external component is a trim piece that covers the flush pedal and valve.  It is held in place by a few screws.
 Back to the inside - As you look down into the bowl, below that black ring which is the neoprene seals, is the flush dome.  It is plastic and the visible part looks like the surface of a ball pressing against the underside of the neoprene seals.  It can be pushed so it rotates on its shaft and locks in the open position, which would leave you looking down into the drain leading into the black water holding tank.  If it broke off, once again, you would be looking down into the black water tank.  That flush dome is the only thing that closes the top of the black water tank from the bathroom.
 That's it for everything inside.  Outside, you have two dump valves.  The forward one is for the black tank and the rear-ward one is for the grey tank.  If one of them is missing, that is a big deal, as the tank contents will drain, unobstructed, onto the ground rather than staying in the tank.  The dump valves have covers that twist on and off, which you open when you dump.  Behind those covers is a flat plastic blade that rides in a track so, when you pull the handle, it opens and drains the tank above it.  Behind that blade is just an open tube leading up into the black tank or to the right to the grey tank.
 OK, that is it for the parts.  What did you once have two of, that you now have one of?  I don't know of two drains or valves below a ring.  The flush dome is one drain below a ring, but you never had two of them.  The dump valves outside are not below any rings, but you should have two of them.
 Once I understand just what you are seeing, or not seeing, I may be able to help.
Ken F in NM
Yahoo Message Number: 157081
--- Just like the TKs until the last couple of model years when the TK's previously separate (and snugged up close to the rig frame) black and grey tank outlets were joined into one. The termination valve on the new TK looked vulnerable to getting hung up with possible less-than-pleasant results; the pipes/valve are angled down to permit better draining, and the configuration looked pretty close to the ground.
Have owners of 2014 and 2015 TKs experienced any problems with "valve snag"?
Yahoo Message Number: 157084
Maybe Ken's fine explanation of MB toilet construction could find its way to the "Companion"?
Re: TK outlet was Re: Toilet in mid-bath
Yahoo Message Number: 157086
Not yet.  I've been in some very interesting Forest Service deep woods camp sites and been  down some rather bumpy roads.  Frankly I was more worried about the tanks then the valves.
Yahoo Message Number: 157088
Ok, appreciate all the responses. I tried to take a picture of this situation, but I am only one person - and holding a flashlight, foot on the pedal to open the valve and taking a picture - its just not happening. Laughing here. So will try to explain a wee bit better with Ken's help.
This issue is not external. And quite frankly, I'd be surprised if it pertained to how it is bolted to the floor or to the holding tanks.  I have never been able to see into my black tank in my mid-bath. When the 3" diameter opening is opened by pressing the external pedal and gets water flowing - I am aware of the seal around the opening, but not what you say is 9" diameter. In fact, can't see what you describe as a "ball pressing against the underside of the neoprene seals". There no ball like element whatsoever. I can not identify the neoprene 9" seals.
Then there is the plastic white ring (is this the flush dome) that is under the opening & sat upon the drains (2 that were connected but split and bent at what appeared to be a 45ยบ angle each way going away from the opening, not one straight down).  Right now, there is only 1/2 of the white ring visible. The 2 drains are now one.  Always thought it was odd they had this on the mid-bath and not the other models. But it is what it is.
If indeed its the flush dome that has broken off... and you say my black tank would be open to the bathroom - that has not happened. And I still can not see into my black tank.
Melinda, who did not want to become intimate with her toilet... but if you insist, will learn. Smiling here.
2011 Mid Bath
Yahoo Message Number: 157089
Bob, there's alot of controversy between the Thetford and the Sealand toilets. Even amongst the different models of each brand. Such as Thetford has a plastic bowl vs Sealand's china bowl.  I suspect is comes down to what works best for your situation.  I do have access to a mobile RV guy, as well as a RV repair place - but not having a clue how to describe all this - its even more expensive.
Here's hoping its a fixable problem vs needing to replace it.
Melinda
2011 Mid Bath
Yahoo Message Number: 157090
Happy its not a disaster in the making...  but am confused by what valve you are referring to that could be stuck open. The only opening (but I guess that is not considered a valve?) is the one in which opens when I press the outside level to get water.
An unexpected education once again... laughing here.
Melinda
2011 Mid Bath
Yahoo Message Number: 157091
"I tried to take a picture of this situation, but I am only one person -  and holding a flashlight, foot on the pedal to open the valve and taking  a picture"
 Melinda, it sounds like you are a prime candidate for a headband light which would free up hands for taking a photo of this situation which no one can seem to visualize without a photo.
Yahoo Message Number: 157093
Melinda,
I would go for the Thetford for 2 reasons:
It is far more common in RV's thus parts availability is better and cheaper. In a marine application I will admit the Sealand is a better choice.
Most RV shops are more familiar with the Thetford. Yes it's plastic but I have never heard of one breaking the housing. If you have to remove it less work and sweat. A 3rd benefit for me is it's much lighter. In my overloaded E-350 chassis anything I can do to reduce weight is a plus, short of giving up my ice cream and pizza.
I don't know what's wrong with your Sealand but it should be repairable short of some manufacturing defect. When I repaired mine I got the parts overnighted to me from Tweety's RV. Good customer service and shipping was reasonable. I wish you good luck in getting yours repaired.
bobmoore14
Happy Thanksgiving to all.
Goldfield Nevada for a few...
Yahoo Message Number: 157094
I second the suggestion by Chris to use the headband light. I got one cheap at Harbor Freight. Great when under the rig doing maintenance or searching for stuff in the outside storage compartments at night. "Now where did I put that wire brush grill scrubber?". I use mine as a backup when riding my trail bike at night with it's antiquated 45 year old electrical system.
bobmoore14
Yahoo Message Number: 157095
2014 TK here.  We've never hit anything although we hold our breaths when we have to do something where the driver's tire is off the curb and the rear is still on it (like when we have to turn it around in our driveway).  The biggest problem we have is when the dump site is slightly elevated.  The terminal valve hangs so low that sometimes it is on level or even below the the dump hole.  It makes for some creative dumping.
Syndi 2014 24' TK Super Flea
BTW, Mid-baths have two holding tank drain valves, one for each tank.---Just like the TKs until the last couple of model years when the TK's previously separate (and snugged up close to the rig frame) black and grey tank outlets were joined into one. The termination valve on the new TK looked vulnerable to getting hung up with possible less-than-pleasant results; the pipes/valve are angled down to permit better draining, and the configuration looked pretty close to the ground.
Have owners of 2014 and 2015 TKs experienced any problems with "valve snag"? Joan
#yiv1533451772 #yiv1533451772 -- #yiv1533451772ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#yiv1533451772 #yiv1533451772ygrp-mkp hr { border:1px solid #d8d8d8;}
#yiv1533451772 #yiv1533451772ygrp-mkp #yiv1533451772hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#yiv1533451772 #yiv1533451772ygrp-mkp #yiv1533451772ads { margin-bottom:10px;}
#yiv1533451772 #yiv1533451772ygrp-mkp .yiv1533451772ad { padding:0 0;}
#yiv1533451772 #yiv1533451772ygrp-mkp .yiv1533451772ad p { margin:0;}
#yiv1533451772 #yiv1533451772ygrp-mkp .yiv1533451772ad a { color:#0000ff;text-decoration:none;} #yiv1533451772 #yiv1533451772ygrp-sponsor #yiv1533451772ygrp-lc { font-family:Arial;}
#yiv1533451772 #yiv1533451772ygrp-sponsor #yiv1533451772ygrp-lc #yiv1533451772hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#yiv1533451772 #yiv1533451772ygrp-sponsor #yiv1533451772ygrp-lc .yiv1533451772ad { margin-bottom:10px;padding:0 0;}
#yiv1533451772 #yiv1533451772actions { font-family:Verdana;font-size:11px;padding:10px 0;}
#yiv1533451772 #yiv1533451772activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#yiv1533451772 #yiv1533451772activity span { font-weight:700;}
#yiv1533451772 #yiv1533451772activity span:first-child { text-transform:uppercase;}
#yiv1533451772 #yiv1533451772activity span a { color:#5085b6;text-decoration:none;}
#yiv1533451772 #yiv1533451772activity span span { color:#ff7900;}
#yiv1533451772 #yiv1533451772activity span .yiv1533451772underline { text-decoration:underline;}
#yiv1533451772 .yiv1533451772attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#yiv1533451772 .yiv1533451772attach div a { text-decoration:none;}
#yiv1533451772 .yiv1533451772attach img { border:none;padding-right:5px;}
#yiv1533451772 .yiv1533451772attach label { display:block;margin-bottom:5px;}
#yiv1533451772 .yiv1533451772attach label a { text-decoration:none;}
#yiv1533451772 blockquote { margin:0 0 0 4px;}
#yiv1533451772 .yiv1533451772bold { font-family:Arial;font-size:13px;font-weight:700;}
#yiv1533451772 .yiv1533451772bold a { text-decoration:none;}
#yiv1533451772 dd.yiv1533451772last p a { font-family:Verdana;font-weight:700;}
#yiv1533451772 dd.yiv1533451772last p span { margin-right:10px;font-family:Verdana;font-weight:700;}
#yiv1533451772 dd.yiv1533451772last p span.yiv1533451772yshortcuts { margin-right:0;}
#yiv1533451772 div.yiv1533451772attach-table div div a { text-decoration:none;}
#yiv1533451772 div.yiv1533451772attach-table { width:400px;}
#yiv1533451772 div.yiv1533451772file-title a, #yiv1533451772 div.yiv1533451772file-title a:active, #yiv1533451772 div.yiv1533451772file-title a:hover, #yiv1533451772 div.yiv1533451772file-title a:visited { text-decoration:none;}
#yiv1533451772 div.yiv1533451772photo-title a, #yiv1533451772 div.yiv1533451772photo-title a:active, #yiv1533451772 div.yiv1533451772photo-title a:hover, #yiv1533451772 div.yiv1533451772photo-title a:visited { text-decoration:none;}
#yiv1533451772 div#yiv1533451772ygrp-mlmsg #yiv1533451772ygrp-msg p a span.yiv1533451772yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;}
#yiv1533451772 .yiv1533451772green { color:#628c2a;}
#yiv1533451772 .yiv1533451772MsoNormal { margin:0 0 0 0;}
#yiv1533451772 o { font-size:0;}
#yiv1533451772 #yiv1533451772photos div { float:left;width:72px;}
#yiv1533451772 #yiv1533451772photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#yiv1533451772 #yiv1533451772photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#yiv1533451772 #yiv1533451772reco-category { font-size:77%;}
#yiv1533451772 #yiv1533451772reco-desc { font-size:77%;}
#yiv1533451772 .yiv1533451772replbq { margin:4px;}
#yiv1533451772 #yiv1533451772ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;}
#yiv1533451772 #yiv1533451772ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#yiv1533451772 #yiv1533451772ygrp-mlmsg table { font-size:inherit;font:100%;}
#yiv1533451772 #yiv1533451772ygrp-mlmsg select, #yiv1533451772 input, #yiv1533451772 textarea { font:99% Arial, Helvetica, clean, sans-serif;}
#yiv1533451772 #yiv1533451772ygrp-mlmsg pre, #yiv1533451772 code { font:115% monospace;}
#yiv1533451772 #yiv1533451772ygrp-mlmsg * { line-height:1.22em;}
#yiv1533451772 #yiv1533451772ygrp-mlmsg #yiv1533451772logo { padding-bottom:10px;}
#yiv1533451772 #yiv1533451772ygrp-msg p a { font-family:Verdana;}
#yiv1533451772 #yiv1533451772ygrp-msg p#yiv1533451772attach-count span { color:#1E66AE;font-weight:700;}
#yiv1533451772 #yiv1533451772ygrp-reco #yiv1533451772reco-head { color:#ff7900;font-weight:700;}
#yiv1533451772 #yiv1533451772ygrp-reco { margin-bottom:20px;padding:0px;}
#yiv1533451772 #yiv1533451772ygrp-sponsor #yiv1533451772ov li a { font-size:130%;text-decoration:none;}
#yiv1533451772 #yiv1533451772ygrp-sponsor #yiv1533451772ov li { font-size:77%;list-style-type:square;padding:6px 0;}
#yiv1533451772 #yiv1533451772ygrp-sponsor #yiv1533451772ov ul { margin:0;padding:0 0 0 8px;}
#yiv1533451772 #yiv1533451772ygrp-text { font-family:Georgia;}
#yiv1533451772 #yiv1533451772ygrp-text p { margin:0 0 1em 0;}
#yiv1533451772 #yiv1533451772ygrp-text tt { font-size:120%;}
#yiv1533451772 #yiv1533451772ygrp-vital ul li:last-child { border-right:none !important; }
#yiv1533451772
2014 TK
The Super Flea
Yahoo Message Number: 157096
" The terminal valve hangs so low that sometimes it is on level or even below the dump hole.  It makes for some creative dumping."
If you have a flusher installed in your black and grey water tanks this won't be an issue. After tank is dumped pump in fresh water via flusher to 75% with valve closed. Then dump again. This will flush tank and dump hose enough to eliminate the unpleasant alternative.
Or you can run a hose thru bathroom window and fill tank via toilet with water pump turned off. Then open the valve and flush this way.
Another solution is to use a macerator but that can be a pain unless you have 12VDC connectors outside near dump valve. Run the engine or generator when using macerator. It sucks a lot of juice from the batteries.
bobmoore14
boondocking at El Capitan for a few...
Hawthorne, NV.
Yahoo Message Number: 157097
OK, focusing in on the flush dome, it is a curved plastic piece that rotates open when you press the flush pedal, opening the way into the drain to the black tank.  It is an off white color.  If it is properly positioned and adjusted, when closed, it will prevent water from flowing from the toilet into the black tank by pressing against the underside of the seals.  In the closed position, it would look like a convex off-white curved surface, circular where visible, and the seals are best viewed at an angle, and form a black ring a fraction of an inch in size between that convex, circular flush dome and the bottom of the toilet bowl.  (The 9" seals are only viewable in that size if you remove the toilet so you would not be able to see them.  My purpose in describing the size was, if one had come apart somehow, and you saw this big, flat, black disk, that would tell us what you saw.)
 I just looked into mine with the flush dome all the way open.  Looking straight down, I can see the underside of the flush dome, then a straight drop to a turn to the right.  There are some mechanisms to each side of the flush dome, involved in keeping it aligned and in place.
 Key questions - is water staying in the toilet bowl, or are you looking straight down into the hole with nothing blocking it?  Is water flowing into the bowl with the pump on but without pressing on the flush pedal?
Ken F in NM
Yahoo Message Number: 157098
Ken, you get the "Technical Writer of the Month" award for yeoman's work in trying to analyze this problem without actually seeing it.
Yahoo Message Number: 157101
I cannot think of a better example of people helping people with their experience and advice on this forum. All motivated by good will and the desire to help without gain.
What a great place and people. Not to be taken for granted but valued and appreciated.
A big thank you to all here.
bobmoore14
Walker Lake, CA. for a few...
Yahoo Message Number: 157107
Ed and Margee, the flush dome is plastic.  I suppose it could break off and drop into the black tank, but I have never heard of that happening.  In any event, based on the back and forth, it sounds as if Melinda's flush dome is intact and the issue relates to something below the flush dome.  I can't wait to hear what that might be or might have been.
Ken F in NM
Yahoo Message Number: 157108
For the record, folks, both Thetford and Dometic/Sealand make a wide range of toilets, including porcelain, plastic and hybrid (plastic base/porcelain bowl) models. (The toilets used by Lazy Daze are in the latter category.) If you're going to talk about toilets, you need to cite specific models.
Yahoo Message Number: 157110
As I have written privately to Chris and Ken - I promise to post my findings on this odd situation.  I am presently seeking out a head lamp to try to take photos, have ordered one, but someone should have one I could borrow.  I have also made an appointment for Blue Sky RV guy (out of Sequim, WA)  to come check out the problem. He can't come until November 30th though.
Will keep everyone posted...
Melinda
2011 Mid Bath
Yahoo Message Number: 157111
bobmoore14
Thx, Bob!  Amen & well-said...I find this site, with all the knowledge & willingness to help (especially helping those of us who are newbies or unskilled at "rocket surgery"), a great blessing.  And I always appreciate the humor (especially when a riff gets going back & forth...like the one a while back on the vicissitudes of life in CA & warning folks away, to avoid the influx of refugees from cold snowy climes like we're currently experiencing here in the midwest).
Lynne LDy Lulubelle, '05 30' TB Lilly, 4-Legged Alarm
Lynne
Lilly, the 4-Legged Alarm
Reply #24
Yahoo Message Number: 157121
"I am presently seeking out a head lamp to try to take photos"
Most cameras, and nowadays even most phones, have built-in flashes. I take it yours doesn't?
