Topic: 2004 factory Sony CD\Radio replacement (Read 22 times) previous topic - next topic
Yahoo Message Number: 156770
Good day to all!
My in dash radio\CD player is well past its prime, and I'm ready to replace it.  I imagine there are some members that have experience with this process, so I'm hoping for some pointers.  Most important, I'm wondering if it's necessary or even useful to remove the engine cover in order to gain access to the back of the old or new player?  I've followed the instructions for removing the old one, but it doesn't seem to be the least bit interested in coming out, and there's really not much to get a hold of to pull on.  It seems like it may need a push, but I don't want to remove the cover if it isn't helpful.
Any suggestions, recommendations or precautions would be welcome!
Bill
2003 - 23'FL
Bill
2003 -- 23' FL
Re: 2004 factory Sony CD\Radio replacement
Yahoo Message Number: 156771
If it is anything like our 2002 MB was, there may be a bunch of the infamous LD caulking gluing the rear of the radio to the mounting bracket.  In our case I had to remove the engine cover to access the rear of the radio and cut away the caulk.
HTH, Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Yahoo Message Number: 156774
"...there may be a bunch of the infamous LD caulking gluing the rear of the radio to the mounting bracket"
---- I haven't tried to un-stick the OEM radio/CD player, but I still occasionally find little blobs of caulk in various places, inside and out, even after 12 years! Whether this speaks to my housekeeping or to LD's "trowel it on" caulking practices, I'm not sure, but I suspect the latter! ;-)
Yahoo Message Number: 156775
In older rigs does anyone know if LD supplied an Alpine radio/cassette player? That's what mine had in it when I bought it used. Its burned up from the lightning storm and I was wondering if I would run into this caulking issue. I want to replace it with an MP3/MP4 player.
bobmoore14
2001 23.5 TK
Yahoo Message Number: 156783
Bill,
 I replaced the radio in our '05 a few years ago. I was able to get the old one out without removing the doghouse. It took a little tugging and wiggling, but it did come out. I have posted an article on the project, complete with pictures and a wiring diagram here.
WxToad @ Stony Fork USFS CG near Wytheville, VA www.ultimatecampgrounds.com www.wxtoad.com
Posted by:   roadienh3 Date: Sun Nov 1, 2015 8:28 am ((PST))
Good day to all!
Yahoo Message Number: 156785
I used Ted's article when replacing the radio in my '02. Did not have to remove the doghouse. Make sure to remove the radio fuse in the engine compartment. I didn't and blew it when reattaching everything.
Yahoo Message Number: 156787
Art, Ted, & Chris,
Thanks to you all for your responses to my inquiry. All of them are helpful. I tried again this morning to remove the old unit without success despite my being certain that I have the clips out of the way so removal should be easy. It won't budge!
I'm curious why Art's unit was caulked in, requiring removal of the doghouse, while the other two weren't. It seems like if LD would go to that trouble on any, it would do so on all. I'm reluctant to remove the doghouse only to discover there isn't caulk holding it in place, but of course I may have to anyway.
For now, I think I'll go cut some firewood for a few hours.  Chain saw is working well, so plenty of satisfaction with that on a lovely day here in NW Arkansas.
I'll follow up when I finally finish the project.  Thanks again!
Bill
Bill
2003 -- 23' FL
Yahoo Message Number: 156790
I assumed at the time it was an attempt to keep it from rattling in the DIN cage.
Art
Art and Barbara
Art's blog
Re: 2004 factory Sony CD\Radio-Follow Up
Yahoo Message Number: 157003
I finally got back to this after a work related trip to Louisiana interrupted my plans, and then some winterizing chores at home.
 I'm happy to report I finally got the old unit out and the new one installed. It was not without difficulties, but it'll be easier next time after having learned a lot. This was mostly because removal of the doghouse, which as others have noted previously, is a PITA.Once it was removed and I got upside down, I could see that the player was held in place by a mechanical connectionbetween the player and a "cage" that surrounded the player. The mechanical connection to the cage was a piece of plastic that was U shaped, with catches, for lack of a better term, that snap onto the cage in a couple of places to hold the deck in place, then were caulked to hold them more firmly in place. No way this thing was coming out of the dash without getting in behind, even without the caulking. Once I had access removal of the old unit and installation of the new went smoothly. There was plenty of room behind the unit and all wiring was long enough to allow splicing the new connector into it out in front of the dash.
 I'm still curious as to why some have this quite secure arrangement and others don't.  Maybe different people perform this same task at the factory and do the install differently, or maybe they have it done by a vendor, which seems a more likely explanation?
 The newly installed (Alpine) unit has an aux input and a USB media port for more ways to listen to music, and, it's much more user friendly than the old Sony as far as navigation, settings and so forth. Sounds great for a good price. Thanks again to all for the observations and suggestions!
Bill
2003 - 23' FL
Bill
2003 -- 23' FL
Yahoo Message Number: 157016
Bill Every one of the half dozen LD radios I have replaced were glued in plac with a big blob of polyurethane.
Rattling radios are non-existence in  LDs.
