Topic: Lug nut covers 2001 MB (Read 13 times) previous topic - next topic
Yahoo Message Number: 153389
Hi. I'm fairly new here. Been lurking, gathering info and learning about my new to me 2001 MB. We found the gem through this forum and met some really lovely folks who owned the coach before us.   They took amazing care of the LD and we are tearing it up!  ;) We had new tires put on recently and on our first trip out the 2 lug nut covers on the rear tire came off. The hubcap was held in place by the valve extenders. At Auto Zone we found some random lug nut covers to hold the hubcap, but the valve extender had unknowingly come loose.  Next stop, flat tire.  Grrrrr.  Cuss cuss.
So, after much searching I find this has happened to others and that the current models have lug nut extenders to hold the lug nut covers in place. Our 2001 has very little thread to attach these lug nut covers.  But after searching I can't find how folks have resolved the problem with these short bolts. Will the current lug nut extenders and covers fit an older LD?  If so, where do I find these items? Thanks for helping and accept my apologies for bringing up a topic that is sure to have been answered already. I just can't find it.
Tanya
Tanya
2001 MB
Re: Lug nut covers 2001 MB
Yahoo Message Number: 153390
Tanya, here's an article from the Lazy Daze Companion about the lug nut covers. You can order them from the LD factory or you can search on the Internet at the Kaper II site.
 http://lazydazearticles.blogspot.com/search/label/Wheel%20Covers KaperII Wheel simulators and Led Lighting
Life With A Lazy Daze RV
Yahoo Message Number: 153391
Also, Tanya, if you click on the highlighted "Life With A Lazy Daze RV" below (above the big Yahoo), it will take you to some photos I posted a while back about how to deal with the wheel simulator lug nut covers.
Yahoo Message Number: 153429
Tanya,
 I may be wrong on this, but if I read your post correctly you have what must be one of the few LD's that were equipped with one of the "not so good idea" wheel covers.  I had a late 2000 Lazy Daze with these and when I asked pretty much the same question you are asking many years ago, all I got were responses about adjusting the lug bolt extenders just like you got.  Unless I'm wrong, you don't have any extenders and the short lug bolts make it VERY difficult to mount the covers properly.  I finally gave up and left the front covers off, as they were the more problematic on my rig and with much pressure on the covers was able to get enough threads on the back ones.  Shortly after our rigs were built, LD went to a new design that used the lug bolt extenders, which is why no one understands your problem.
 My final conclusion was that I would buy lug bolt extenders (available at most tire dealers) and enlarge the holes in the wheel covers to accomodate the larger bolt size and then try to find some matching fancy nuts to hold them on.  I ended up selling my rig before I did any of this, however, so I can't tell you how that would have worked out.
Good luck,
Rich - Former 2000 MB, now Montana 5th wheel
Yahoo Message Number: 153431
I bought lug nut extenders and matching acorn covers for the rear wheels on our 2001 from the factory about a year ago. You do have to enlarge the holes in the wheel cover. They work fine.
Search Amazon for this drill bit - it makes it easy to enlarge the holes in the wheel cover.
Neiko 10194A Titanium Step Drill Bit 1/4' to 1-3/8' in 1/8' Increments, 10 Steps
Ray Hetterscheidt
Yahoo Message Number: 153432
Thanks for the responses.  Much appreciated.
Rick, you've described my issue exactly. I did call Lazy Daze and they told me I had to drill holes for the extenders, just as Ray described in his post.  So, for now I've done nothing. I have mismatched lug nut covers.
Tanya
Tanya
2001 MB
