Topic: Need flat-screen TV mounting plate for 2004 RB (Read 38 times) previous topic - next topic
Yahoo Message Number: 152882
Our 2004 RB was broken into and the tv was stolen.  I wish they had just taken the tv, but rather than removing the tv from the mounting plate, they removed the mounting plate from the arm and stole the whole assembly.  Now I have the extending arm with vertical mounting holes at the end of the arm, but no mounting plate.
 LD informs me that the flat-screen tv mounts are custom made for LD, and they no longer use the type on the 2004 for the current models.  I believe 2004 was the first year LD installed flat screens (Sharp 15" in our case).
 The tv stolen was a Samsung 21" that I had purchased and installed as an upgrade to the original Sharp and fit beautifully with the original mount plus a VESA adapter plate required for the VESA-compliant Samsung.
 Any ideas on how to solve the problem?  I am loathe to replace the entire mounting arm assembly, so hope there is a way to work with the existing hardware.
Thanks--Ted
Re: Need flat-screen TV mounting plate for 2004 RB
Yahoo Message Number: 152888
I'm somewhat "mechanically challenged," but maybe you could find what you need in this link from Amazon.
 http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=vesa+mount+hardware+samsung&rh=i%3Aaps%2Ck%3Avesa+mount+hardware+samsung
Cheryl
Cheryl (a.k.a. Desert Diva)
2002 Honda CR-V
Yahoo Message Number: 152893
The best solution would seem to take a VESA plate and mount two ears on it to fit the vertical holes in the arm. These ears could be mounted by screws or welding.
The original plate was thick steel with two thick ears welded to it. That could be duplicated at a welding shop with a drawing.
Much easier to replace the stolen plate than replace the arm as the original is extremely strong and durable.
Nothing new will match it. Just an opinion.
Harry 2006RB with the custom made TV mounting arm.
Harry 2006RB
Yahoo Message Number: 152899
I used this and I did drill a new hole a little below where the holes in the wall were already. I wanted to lower the screen a bit for less neck pain while viewing. The product was dead easy to put together.
VideoSecu TV Wall Mount Articulating Arm Tilt Swivel Bracket for most 15-27" TV Monitor Display VESA 100X100 75X75 up to 33LBS ML15B A28
by VideoSecu
It's at Amazon and was only $19.99 and Iove that the screen connection is separate from the wall connection. This makes it easy to put up the wall mount and then attach the TV.
Andrea Eagles
2007 RB
Yahoo Message Number: 152901
Harry--
 Your take is exactly mine.  You get it!  If you could  take photos of yours at different angles, I could give them to a welding  shop, and that would be a huge help.  Please PM me:  traphael a*t rapgroup do*t co*m (delete the *s).
 You understand my problem and how I hope to fix it.  Your help here is greatly appreciated.  With no help from LD on parts, I am really stuck.  If only there were an LD graveyard for scavengers.
Thanks--Ted
Yahoo Message Number: 153082
Thank you for your response.  I do not see a locking mechanism to secure the mount and tv while the coach is in motion.  How is that accomplished?  Thanks--Ted
Yahoo Message Number: 153083
Ted, I have an o7MB.  The arm is not secured.  I use a bungie cord or just leave it.  That said it does not move very much.
Previously: 2007 Mid Bath
Yahoo Message Number: 153086
You could use this but I think it's overpriced: Choice TV Mounts - Lucasey TV Mounting Systems
My LD came with a wood shelf installed for TV. I had my Jensen flat screen TV mounted using wood screws and washers thru the stand into the shelf. You cannot rotate it that way but it doesn't cause me a problem.
bobmoore14
