Topic: LP gas detector for 2000 LD (Read 17 times) previous topic - next topic
Yahoo Message Number: 152692
Tom and Kristen: You probably need a new LPG detector. I replaced mine last  year with this one from Amazon. It is a flush mount, brown detector that will  fit in the hole your present detector was in. Available from Amazon for about  $62, a Marine technologies 30-442-P-BR. Propane and other explosive gasses are  heavier than air and settle low. More easily detected near the floor, this  detector is best mounted near the floor.
The carbon MONoxide detector should be mounted on or near the  ceiling. A result of incomplete combustion the CO gas could be warm and  accumulate near the ceiling. This model, ARIKON Battery Powered LCD CO Carbon Monoxide Poisoning Alarm  Sensor Detector -White, is also available from Amazon for about $12. It will  cover up those two ugly holes in your ceiling. These detectors are available in  many locations besides Amazon. Hope this helped. RonB and 'Bluebelle' a '99  TKB
Re: [LD] LP gas detector for 2000 LD
Yahoo Message Number: 152695
Ron Called Safe Alert company and they said since it was 5 years old it should be replaced.
I will buy two seperate detectors as well rather than buying a duel unit.
Thank you for the time you took to respond.
Tom -- Sent from myMail app for Android
 Monday, 11 May 2015, 11:35AM -07:00 from "rntb00@... [lifewithalazydazerv]" :
