Topic: Replace flooring (Read 19 times) previous topic - next topic
Replace flooring
Yahoo Message Number: 152049
We had a water pump leak so had to remove carpet and are thinking of replacing with vinyl planks, but found that there are large bolts that stick up. Might be easier to replace with carpet. Does anyone know of an installer in the ventura county area.
 Sent from Yahoo Mail on Android
Re: Replace flooring
Yahoo Message Number: 152050
You can lay 1/4" plywood down over the floor and router around the bolts (or an installer could do it). We did this before installing vinyl planks ourselves. Definitely prefer the new flooring to the old carpet. One thing that might not be an issue for you given your location - we live where it got below freezing during the winter. We winterized our RV for the season and had a small heater going through most of the winter (but not all due to a neighborhood power issue), and I've noticed there are some planks that have loosened at corners, presumably from the temperature extremes. Easy fix, but could be an annoyance to some.
Yahoo Message Number: 152063
If you get a thicker flooring, you can use a Forsrner bit to make a hole in the bottom flooring that will cover the bolts (do not drill the hole all the way through!.
We did this on tout 1985 LD and it was easy, cheap and worked like a charm.
Alan and Carol 85 White Ghostt
Yahoo Message Number: 152068
When we replaced the carpet with engineered wood, we found the propane tank bolts setting above grade. Our fix was to countersink flat head plow bolts and a washers that would lock the bolts in place. The washers were modified to lock the bolts. To keep the washers from spinning we screwed them to the floor. The countersink holes were then filled with glue.
 We would have used elevator bolts, but could not get the length we needed; 3 ½".
If you want to see a pic, let me know.
Tim
Yahoo Message Number: 152102
Yes, thanks, Tim and I did send a private response message which obviously did not get to you. Nice job on your floor, especially with the bolts. I will try to send the message again.
