Topic: How to remove LD coffee maker? (Read 10 times) previous topic - next topic
Yahoo Message Number: 152038
Anyone know how to "pop"or release the factory installed coffee maker from the steel frame that attaches it in the corner of the mid-kitchen models just above and behind the sink?  I expect no trouble removing the steel frame after I figure out how first to take off the coffee maker.  I do not want to break off any parts.
Re: How to remove LD coffee maker?
Yahoo Message Number: 152040
Bob, I removed the one on our '02 30' many years ago and if I recall, I had to remove the microwave to get to the mounting bolts. If this was the case, the microwave came out easily. Have you stuck your head in the corner cabinet to see what's behind there? I'm guessing you have.
Yahoo Message Number: 152043
I've been working on the same problem. I can't see around the back - does the microwave just slide out and unplug if needed rather than being wired in?
Pat
The Pearl - 2000 31'
"Of all the things I've lost, I miss my mind the most."
Yahoo Message Number: 152045
In my '02 30' it easily slides out after removing the screws that hold it to the frame it sits in. There is no wiring except the standard cord which comes attached to it and is plugged into the hidden outlet. While it was out I attached a 5-outlet power strip under the cabinet in the corner where the coffee pot was and plugged it into the circuit-dedicated outlet for the microwave. Now I have another power source in the kitchen area to use without overloading the one above the sink or at the end of the sink cabinet near the power center.
Yahoo Message Number: 152089
Under front end of passenger side twin bed. The Swing handle is accessible by opening the floor level cabinet door adjacent to the end of the bed base. Easy to access, easy to open and close the valve handle.
Yahoo Message Number: 152090
Chris, that's the way to go. Thanks. I removed the coffee maker from its mounting frame by tilting it down and sliding it out under the adjacent fluorescent light fixture and cutting the electrical cord. I still need to remove rhe microwave so I can remove the bolts To release the coffee maker mounting frame.
Yahoo Message Number: 152093
Thanks Chris. And great tip about the power strip - that solves another item on my to-do list!
Pat
