Topic: Tow Hitch 23.5 TK (Read 17 times) previous topic - next topic
Tow Hitch 23.5 TK
Yahoo Message Number: 151514
I climbed under the LD the other day to inspect my trailer hitch assembly on our 1997 23.5 TK. There is a trailer hitch bolted to the bottom of the factory bumper, and I wanted to see how it was supported and attached. I thought that maybe I'll have to install some higher strength bolts.  I assumed that being a 23.5, (E350 chassis), the frame from Ford would extend all the way to the rear.  However, what I discovered is the frame is probably 1 1/2' short, and a 3" "C" beam is bolted to the chassis frame to extend out to the bumper. For our sailboat we intend to tow, this just won't be acceptable. So I'll need to fabricate a stronger extension on the frame to support the tongue weight and weight of the trailer and boat. My friend has a 27' LD on a E450 chassis and they tow their jeep with no problem, (4,500 Lbs, which is comparable to my boat and trailer weight), but a toad won't have the tongue weight that I'll have. Hopefully someone has already solved this issue, or knows a direction to point me.
Thanks in advance,
Don
Re: Tow Hitch 23.5 TK
Yahoo Message Number: 151516
Doing a search of the message board (and the Photos section) will bring up many posts on the topic of hitches/towing/weights, etc. This compilation from the Lazy Daze Companion also provides good information:
http://lazydazearticles.blogspot.com/search/label/Hitch
You will probably receive information and advice from those who have significantly upgraded the hitch assembly for safe towing; hopefully, some of those responses will be from towing owners who have the 23.5' E350 (11500 GVWR).
As ever, YMMV.
Yahoo Message Number: 151517
Don, If you reside in SoCal I can recommend a good place to have the necessary braces/hitch fabricated: Eckharts Trailer Hitch & Welding, Inc. SINCE 1944
Eckharts Trailer Hitch & Welding, Inc. SINCE 1944 Eckharts Trailer Hitch & Welding, Inc We are open to serve you: Monday - Friday 8am - 5pm Sat 8am - 1pm closed on Sunday WEST LOS ANGELES               2352 So.
View on www.eckharts.com
right
My 01 23.5 TK was done there. I tow a Jeep Cherokee no problems.
Bob
