Topic: Replacing the Converter - a DIY Job for a Novice? (Read 9 times) previous topic - next topic
Yahoo Message Number: 151350
Hi All
I had a little battery scare  - everything was fine till I plugged into shore power for a week, then the batteries didn't seem to want to charge or hold a charge. After topping up the water and taking a couple little mini trips, they seem just find now.
 Since then I've been researching possible causes and solutions, and it looks like I might want to upgrade my converter from a Magneteck to a Progressive Dynamics of some sort, which seems to be the favorite.
 Two questions - is this a job for someone with basic repair skills but little experience with electrics and which Converter would best suit my 2000 30' Lazy Daze?
Many thanks
Pat
The Pearl - 2000 31'
"Of all the things I've lost, I miss my mind the most."
Re: Replacing the Converter - a DIY Job for a Novice?
Yahoo Message Number: 151355
" is this a job for someone with basic repair skills but little experience with electrics'
Pat
If you have little or no experience with 120-VAC electrical, I would suggest having an experienced electrician install your new converter, it helps to know what you are doing. A wrong connection can cause serious problems.
Many converters require changing the 12-volt fuse panel, lots of fun if you have never done it before.
Yahoo Message Number: 151358
Yahoo Message Number: 151374
Looking at the pictures, I think you're all right - this may be a bit beyond my skill level...
Thanks!
Pat
