RV Quickie Flush November 16, 2014, 04:25:44 pm Yahoo Message Number: 149563Hello,I am about to pick up a new 2014 27' mid-bath, and one of the first things I intend to do is install a Camco Quickie Flush on my black tank.Which side of the tank should I mount it on? The instructions seem to indicate that it should go on the side directly across from the dump outlet. Is that side toward the rear of the vehicle, and will I be able to get at it?Thanks a Lot, Tim
Re: RV Quickie Flush Reply #1 – November 17, 2014, 11:15:34 pm Yahoo Message Number: 149583"The instructions seem to indicate that it should go on the side directly across from the dump outlet. Is that side toward the rear of the vehicle, and will I be able to get at it?"The dump outlet is at the rear, so the nozzle should be mounted at the front.For what it's worth, over the years I've been though several of these tank flushers (of various brands), and they all clogged and became unusable after a year or two. I find I do better backflushing with a Camco HydroFlush elbow attached between the sewer hose and the dump valve.Andy BairdTravels with Andy
