Topic: Power Step Upgrade (Read 11 times) previous topic - next topic
Power Step Upgrade
Yahoo Message Number: 149533
I want to get a power retractable step for my LD. Has anyone had there older LD with the manual step upgraded? If so what unit did you use? What is the AMP draw from the electric motor?
Thank you,
Bob
01 23.5 TK with toys...
Re: Power Step Upgrade
Yahoo Message Number: 149539
"I want to get a power retractable step for my LD. Has anyone had there older LD with the manual step upgraded? "
Bob
The only type I have seen on LDs are the Kwikee steps. The power step should bolt right up.
The harder part is running power and a wire from the ignition  to the controller and then up to a new wall switch.   It can be done.
Amperage draw is fairly low, the step's motor is just a power window motor.
Yahoo Message Number: 149570
"Can you tell me if this model is compatible with my LD:"
Bob
You want the single step model.
http://www.amazon.com/Kwikee-902809025-1-Step/dp/B000BRJSVE/ref=sr_1_10?s=automotive&ie=UTF8&qid=1416195572&sr=1-10
