Bypassing inverter for TV electronics November 09, 2014, 05:03:44 pm Yahoo Message Number: 149397Good day!I apologize in advance if this topic has been covered already. I could not find a clear answer in the archives.Is it possible to bypass the inverter so that the TV electronics tap directly into the exterior shore power? I ask because the inverter is running all the time when I have the TV on and since I never watch TV while boondocking, I thought I'd ask. The inverter fan kicks on regularly. Since I have 120 V, my thought is why convert it to 12 volts and then back to 120?Just interested. Thanks for any info.Dan26.5' 2003 RBSan Juan Bautista, CA
Re: Bypassing inverter for TV electronics Reply #1 – November 09, 2014, 05:14:24 pm Yahoo Message Number: 149398"Is it possible to bypass the inverter so that the TV electronics tap directly into the exterior shore power?"If your TV uses 120 VAC, as your message implies, then you can run it on shore power (or for that matter, generator power). Just plug into any 120 VAC outlet other than the special one dedicated to the built-in inverter.Andy BairdTravels with Andy
Re: Bypassing inverter for TV electronics Reply #2 – November 09, 2014, 05:54:34 pm Yahoo Message Number: 149399Thanks Andy. Is it possible to retire the special outlet so it connects directly to 120V?--Dan
Re: Bypassing inverter for TV electronics Reply #3 – November 09, 2014, 06:37:45 pm Yahoo Message Number: 149400That should be rewire, not retire. )). --Dan
Re: Bypassing inverter for TV electronics Reply #4 – November 09, 2014, 06:51:03 pm Yahoo Message Number: 149401"Just plug into any 120 VAC outlet other than the special one dedicated to the built-in inverter." Which means you might have to run an appropriate extension cord to the closest 120 outlet depending on your floorplan.Chris H 2002 30' IB
Re: Bypassing inverter for TV electronics Reply #5 – November 09, 2014, 10:36:03 pm Yahoo Message Number: 149402"Is it possible to rewire the special outlet so it connects directly to 120V?"I suppose you could, but I wouldn't.In fact, I didn't, even though I have a whole-house inverter that can power all my other 120 V outlets even when I'm not plugged in. But I left that one outlet just as it was, figuring that the factory-installed 400 W inverter may be useful as a backup. TV? Naw, I don't even have one. But I might want to run my computer from that outlet in an emergency, or charge some device that doesn't have a 12 V adapter. Who knows? It seems foolish to throw away the capability. I might need it someday.Andy BairdTravels with Andy
Re: Bypassing inverter for TV electronics Reply #6 – November 10, 2014, 12:03:27 am Yahoo Message Number: 149403Apparently, the 400W inverter used by LD does not have a transfer relay in it? I ask because my similar SOB uses a 400W inverter that does have a transfer relay in it, so that socket supplies grid power whenever the motorhome is connected to shore power (or to the generator if I'm using that).Eric Greenwell [lifewithalazydazerv] wrote, On 11/9/2014 8:36 PM:
