Topic: 'Humming' from the converter (Read 16 times) previous topic - next topic
Yahoo Message Number: 149392
Pat and others. It could just be the fan turning on and off. There is a fan  inside that runs when it gets warm. If it is real quiet you can hear it. It is  Normal. Magnetostriction causes all transformers to hum a little, but is normal  also. If the converter is working, relax. It is not a 'ticking time bomb'.  RonB
Re: 'Humming' from the converter
Yahoo Message Number: 149394
I agree that while the hum can be irritating, nothing dramatic is likely to happen.
But the old converters still have have two issues.
1 - They are very slow at recharging batteries and nearly worthless on a generator when boondocking.
2 - They tend to overcharge batteries and "boil" off water when left on shore power for long periods.
Our batteries lose very little water since I put in a PD 9270.
Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Yahoo Message Number: 149420
Well, my main concern is what will happen to the batteries if they get overcharged - and after a few days of shore power, I'm starting to have problems with them holding a charge. Going to check the water levels tomorrow. I'm unplugged now, but definitely want something to protect (and to avoid replacing) the batteries.
 So, would an RV supply/repair shop be the best place to go, or should I call my friendly local electrician?
Pat
 PS So glad it wasn't a bomb I was hearing RonB
The Pearl - 2000 31'
"Of all the things I've lost, I miss my mind the most."
Yahoo Message Number: 149441
Local RV supply/repair shop, or  online. If you're a Good Sam member, and there is a Camping World nearby, the  installion on a purchase from them is reasonable.
 My buzz box was easy to replace (not in an LD), label the  plus & minus (+12 Volts and ground) wires to the fuse panel, unfasten  them from the old box, unplug the old box from the AC outlet and  remove a few screws.  The new converter fit in the space where the old one  was (doesn't always happen that way), so all I had to do was fasten the new one  in place, connect the 12 V wires from the fuse panel and plug it  in.    If the laws of Murphy didn't strike, you're ready to  go.
RonC
2a  Re: 'Humming' from the converter
Mon  Nov 10, 2014 3:51 pm (PST) . Posted by:
Pat
Yahoo Message Number: 149449
I thought I read some where that you can have a disconnect switch or something like that when your plugged in to shore power so you won't over charge your battery or was it when you are storing your rig ? ? ? ?
Yahoo Message Number: 149451
"I thought I read some where that you can have a disconnect switch or something like that when your plugged in to shore power so you won't over charge your battery or was it when you are storing your rig ?"
A disconnect switch has long been a factory option on new Lazy Dazes, and can be added to older ones. These switches prevent anything from charging--or using!--your batteries, so they are useful only when your rig is in storage.
Travels with Andy
Yahoo Message Number: 149463
Thanks Ron. Unfortunately, I very well acquainted with Mr Murphy, so as I'm a Coachnet member, I'll be checking with them on recommendations for a service center...
Pat
