Topic: Volume of Dometic Fridge- ammended (Read 10 times) previous topic - next topic
Re: Volume of Dometic Fridge- ammended
Yahoo Message Number: 148670
Susan, the interior (storage) volume of your fridge is 6 cubic feet. All 23.5'/24' and 26.5'/27' Lazy Daze models have used this size for many years. The 30.5'/31' LDs have 8 cubic foot fridges.
Travels with Andy
Yahoo Message Number: 148671
Susan,
According to Dometic catalog dated 2008, the model you have can be replaced by then current RM2652, RM2662, or RM3762. The first two are 6 cu. ft. and the third is 7 cu. ft.
The current Dometic website does not list the first 2 models but does have DM2652 and DM2662 which be replacements with updates to cover the recall fixes.
I have a 2005 MB, and at the time all the 26 1/2 footer LD models were 6 cu ft.  I had Dometic model RM2662.
When the cooling unit in my fridge died in 2008, I replaced it with a Dometic model RM3762 which has the same "form factor", i.e. outside dimensions and arrangement gas line couplings, electric connections, etc.  Because of improved insulation materials it has thinner walls and is 7 cu. ft. with the freezer getting proportionally a bigger bump up.
Alex Rutchka, SE #4
Yahoo Message Number: 148672
I wonder if any of you can assist me with my manual satellite dish. We have a 2004 RB and have no problem with setting the elevation. When turning the dish it is hard to rotate. Is there a way to lube the device so it turns easily.
Thanks Greg in Yorba Linda, Ca
Yahoo Message Number: 148673
Greg, my manual is not handy to see if it states anything about rotational lubricating, but I would suggest you call Winegard tech services( 800-788-4417) with your model # in hand and see if they have any suggestions.
