Topic: Water leak in RK (Read 16 times) previous topic - next topic
Water leak in RK
Yahoo Message Number: 148650
Hi again; I may have found my problem.  Made some assumptions which were not correct.  I assumed there was no water at the pump as I saw none on the house floor and the pump was not cycling which it would have done if there were a leak.  I finally pulled the draw, saw a small amount of water, checked the fittings, and noticed that there was water around the connection of the strainer!  I guess the strainer gets loosened from all the vibrations.  I screwed it tight and hope for the best.
I saw no water dripping from the battery box this morning.  However, it is a cool low 40 this morning and I will check again and more thoroughly when I return to the coach later today.
Mike Lewis ___ The #1 Worst Carb Ever? Click to Learn #1 Carb that Kills Your Blood Sugar (Don't Eat This!) http://thirdpartyoffers.juno.com/TGL3131/541c16859d0c716850575st01vuc
2007 RK
