Topic: stove splashguard (Read 9 times) previous topic - next topic
stove splashguard
Yahoo Message Number: 148434
What material do you use to make a splash guard to protect the wall next to the stove? I was thinking of a piece of Lucite, but am concerned about flammability. What materials have you used, and how do you attach it to the wall? Thanks for your thoughts! Wendy
2002 MB
Re: stove splashguard
Yahoo Message Number: 148438
I use sheet plastic It is more than far enough away from the stove. It  never gets warm. Attach with double stick tape.
 I found later that Home  depot has glass's for sale and they will cut it. If not HD it was Lowe's. And  the price is real cheap. It is only single strength as I recall. The have clips  that are used to hang mirrors that you can use for this.
One of them quit cutting glass I think they no longer carry glass
George
retired plumber
Yahoo Message Number: 148439
About seven years ago I covered the walls surrounding the stove and sink in my 2003 midbath with cheap self-stick vinyl tile. The tile's adhesive wasn't strong enough to hold it to a vertical surface, so I used Goop adhesive. The entire job took about two hours and cost less than twenty dollars.
In the years since then I've done a lot of cooking and baking, but the tiles show no sign of distortion from heat. I did have to re-glue a couple of pieces last year, but they weren't ones that were near the stove.
I love the look of the tile, and the ability to wipe it clean is a huge improvement over the dirt-holding texture of the original wall covering.
Travels with Andy
Yahoo Message Number: 148455
For a clean industrial look, some have used polished aluminum sheet metal, with either the embossed side or smooth side showing. I believe Kate Klein was the first one I saw using it.
http://www.lowes.com/pd_241558-37672-11256_4294684417__?productId=3054573&Ns=p_product_qty_sales_dollar|1&pl=1¤tURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=
Yahoo Message Number: 148995
Take a look at FRP paneling at Lowe's or HD. It's a plastic used commonly in areas exposed to high moisture, about 1/8" thick I think. They have a corner molding for it to hide the raw edge. One side is bubbly and the other side is smooth.
Mark
