Topic: Already an "opportunity to excel" - Brake Problems (Read 20 times) previous topic - next topic
Yahoo Message Number: 148219
I figured my first challenge would be figuring out how to organize the dishes in the kitchen, but no, it seems I have a brake problem. I was planning on taking it in for a checkup anyway, but I've got to get there first.
 The symptom is a hard pull to the right which started about 5 or 6 miles into a drive around the block, and a very "hot" smell when I stopped. The tires look OK. I called the shop and they said it might be a frozen caliper, and I know it did sit over the winter and hasn't been driven much since.
 As I have access to a jack and a good set of wrenches, is this something that I can loosen up enough to get to the shop (about 40 miles away)? I have some basic mechanical experience, and I think I know enough to stop before I do something really silly.
 Should I give it a go? Any advice on a good YouTube video to walk me through it?
Many thanks...
Pat 2000 30 IB - The Pearl
The Pearl - 2000 31'
"Of all the things I've lost, I miss my mind the most."
Re: Already an "opportunity to excel" - Brake Problems
Yahoo Message Number: 148220
You may get suggestions from the mechanics of the board, but without a *lot* more information, it's impossible to diagnose or to suggest a "fix" or a how-to video. It may a simple fix or it may not be; I wouldn't "loosen" or mess with anything, and I wouldn't drive it 40 miles and risk further damage to whatever component(s) is/are causing the problem. (To say nothing of "control" problems of driving a large vehicle which pulls hard to one side.) What I *would* do is to call the shop again and find out if one of their mechanics will make a "house call"; if not, I'd either look for a more local-to-you mechanic who could check out the problem onsite, or call your road service provider and have it towed to the shop.
YMMV, of course. Good luck and please post when you get a diagnosis! Thanks.
Yahoo Message Number: 148232
Hi Pat-
 My 2003 MB suffered a similar fate last weekend.  We were all packed up for a trip and 10 miles into it I knew something was wrong.  The coach was pulling right and didn't have the usual get up and go.  The right front brake was seized.  I let it cool off and the brake un-seized.  I drove it back home although I'm pretty sure that caliper isn't working at all now.  I had an IR thermometer and some experience with car brakes to help with basic troubleshooting.
 From what I've read, front brake problems aren't uncommon on E-450's.  Problems I've read about include stuck caliper pistons, stuck slide pins, and worn out flex hoses (they collapse and prevent pressure from releasing).  Without some disassembly, I doubt anyone can tell you what your specific problem is.
 My plan is a full rotor/caliper/pads/bearings/hoses replacement on the front end.  It's overkill, but at 10 years old, 55k miles, and lots of sitting (opportunity for things to rust and seize) I'm not interested in messing up another trip with a partial fix.  I plan to do the rear brakes before long as well.
 A good mechanic could probably id the exact problem and get you back on the road with fewer new parts.
 My next step, if cooling hadn't loosened the caliper, would have been a  call to Coach-Net.  I wouldn't drive 40 miles if I knew the brake was  stuck.  The good news is that parts aren't hard to find.  The bad news  is that I paid $500-$600 just for parts.  I've read $1200-$1500 for  parts and labor.
These links might be of interest (Thanks to LarryW for sharing) : Life With A Lazy Daze RV
Brakes
Ain't RVing fun?
Rich 2003 MB in NC
Yahoo Message Number: 148233
"As I have access to a jack and a good set of wrenches, is this something that I can loosen up enough to get to the shop (about 40 miles away)? I have some basic mechanical experience, and I think I know enough to stop before I do something really silly."
You will need a very big hydraulic jack to lift a wheel on a 12,500+ pound vehicle. Are you sure it's worth the risk of getting hurt? When I bought my LD (it's an E-350 chassis, not 450) I had the entire brake system replaced including the hoses by a competent mechanic. This was at 62K miles. I now have 80K plus miles and no problems. I also tow a toad with motorcycle attached.
Bob 01 23.5 TK with toys in tow.
Yahoo Message Number: 148235
Thanks for the replies. It sounds like it may be time for a complete brake job, just wish I and found it out at the shop rather than the driveway!
 I took a peek at Coach-Net and I'm considering their Basic package - as Yahoo's search feature is still out of commission, has anyone had any experience using their service?
Thanks again...
Pat
Yahoo Message Number: 148236
-Pat wrote in part, "...I took a peek at Coach-Net and I'm considering their Basic package - as Yahoo's search feature is still out of commission, has anyone had any experience using their service?"
Pat Gina and I have Coach-Net.  When we got Da Vee we replaced our AAA service them.  We had a few incidents with very slow service with AAA.  For some reason, maybe just the person I was talking to, adding the RV to the existing cars seemed more difficult than it should have been.  Coach Net was just much easier.
 I have had to use them three or four times with our cars.  A flat with the RV (actually a tire that kept loosing air) and twice with major car issues where each car needed to be towed to a shop.  The response was fairly quick, the time with the RV I was near Norfolk VA, the others I was home.
 The discussion board here, on RV.net and one or tow others that I no longer lurk had many good reports about Coach Net.  After signing up I have read a few bad reports too.  Most the bad incidents took place in less populated locations where the pool of mechanics is smaller. I suspect AAA and other services would suffer in those locations as well. All the services had some complaints about slow service from time to time so I guess I have been lucky in my calls.  Over all I like the service because of the primary concern for the customers safety in the questioning script used by Coach Net operators. I also like how they stay in contact by return calls. It is a (small) notch above the script and service I remember when using AAA.
 We have not used other features of the service and actually don't know if they exist. When we had AAA we used the heck out of their trip planner service (actually talking to a person in a store about routes and what we wanted from the trip speed vs sight seeing on different legs and the like), maps, hotel books and guide books.  We have not really needed those services recently - even before the RV.  With higher speed internet coming to the tech toys at home and now in the car those services once used at AAA have become less important to us while traveling.  I mention them because while they have become less important to us; AAA does them very well and those services may be more important to others.
Good luck with the brake job.  I hope you are on the road soon.
John 07 Mid Bath
Previously: 2007 Mid Bath
Yahoo Message Number: 148241
Pat, I'm sorry to hear about your brake problem. To answer your question, many of use use and recommend Coach-Net, after having tried other services.
Travels with Andy
Yahoo Message Number: 148243
Thanks Andy and John - I hope I won't use their services often, but I think it's a good idea to have the extra protection.
 I am going to have a go at trying to loosen things up myself though, you never know, I might get lucky. If it doesn't work, at least I'll have a Plan-B.
Pat
Yahoo Message Number: 148244
--- You might want to check to see if the insurance policy on your rig covers emergency road service and towing; check the coverage very carefully to discover any exclusions or "gotchas".
I realize that not everyone feels that carrying an emergency road service is necessary or desirable, but, speaking from my own experience, I wouldn't leave the driveway without it; for me, it's a basic requirement, particularly as an "older" solo traveler. I've subscribed to Coach-Net's basic plan for 5-6 years; fortunately, I have not had to test their service quality, and I hope not to, but if/when I do, I have no reason to believe that the service will not be there. (As long as one has a cell signal, of course, and that can be problematic since I am often traveling in "towerless" or "deadzone" places!)
I do carry "equipment" and spares of essentials, and I can do some fix-its and general maintenance, but I'm also realistic; I *know* I can't push the thing, and I am pretty sure that I would not be able to change a tire (maybe the front if I could get the lugs off, even with a breaker bar, but probably not the rear) or installing an engine belt or doing a side-of-the-road brake repair or whatever else goes blooey to the point of "no go".
Obviously, buying emergency road service coverage is a "YMMV" thing; for me, having it is essential.
Yahoo Message Number: 148249
Like Joan, we would not leave home without it!  We have used Coach Net for our near eleven years of LD motor homing and have used it several times with excellent results.  I did extensive research before going CN, and they won hands down.
Bob 30IB AE
Kathy and Bob on the Go
Yahoo Message Number: 148250
I've had my LD towed a couple times to get to service. Great AAA service here in Orange County and got me to the place I needed to go.
Yahoo Message Number: 148252
"Obviously, buying emergency road service coverage is a "YMMV" thing; for me, having it is essential."
I couldn't agree more. The one time I had to use Coachnet was essential. I have the platinum coverage and they towed my Jeep toad when it broke down to the mechanic of my choice. The cost is minimal for the peace of mind it gives. Better service than the Good Sam coverage.
Yahoo Message Number: 148255
Great AAA service here in Orange County --- Just a FYI: AAA is a regional operation; each region has its own policies and offerings, and a service or coverage available in one region may not be in another. For example, the Automobile Club of Southern California does offer an "RV Plus" plan; it's likely the plan you have if you needed service in Orange County and that's your home region. Calstate AAA (AAA's regional name in northern California, Nevada and Utah) does not offer RV road service coverage. If one has "AAA" (by whatever name in whatever area)  and assumes that its road service extends to covering an *RV* for towing or road service, I suggest checking the policy coverage very carefully to make sure that the services expected are going to be delivered whenever and wherever they're needed. While AAA's "RV Plus" coverage might work in one's home region, will a service provider show up - with the appropriate equipment, if at all - when you're in a different region?
This paragraph from the AAA website may help to find out what AAA does and doesn't offer as far as RVs go in your home region and elsewhere:
"Does AAA provide Emergency Roadside Service for RVs and Motorhomes?
AAA does provide services to RVs and Motorhomes on a limited basis. Your RV/Motorhome may be covered as long as the contract station that is dispatched to service your vehicle has the equipment available to perform what is necessary. Services that are provided are covered up to $300.00. In some cases, this may be on a reimbursement basis.
Contact our AAA Emergency Road Service to inquire if your particular vehicle is eligible for service. To contact AAA Roadside Service, please call (800) AAA-HELP ((800) 222-4357) 24 hours a day, 7 days a week."
AAA is great for cars, and their road maps, although a lot fewer than in years past, are still among the best. I don't use their "trip planning" or tour books, but I keep up my 40+-year membership for the maps! ;-)
As ever, YMMV.
Yahoo Message Number: 148256
Joan puts it well. When I see words like "on a limited basis," "may be covered," and "In some cases," I know that I can't rely on that service in an RVing emergency.
Coach-Net, on the other hand, has saved my bacon several times.
Travels with Andy
Yahoo Message Number: 148259
I checked my Progressive policy first, and while they do list towing, the wording made it sound very limited. Having had too much experience with older vehicles, including a different motorhome, I know only too well the curve balls they can throw you - last time I drove the Airstream it threw a belt and I lost power steering AND brakes in the middle of nowhere, and it cost him-indoors a bundle to have it towed.
 I'm not so mechanically inclined that I'm comfortable tackling anything major, but I hope to at least do some of the basic maintenance tasks - oil change, air filter, plugs (maybe). I would prefer to have someone else change a tire if possible, especially if I'm on the side of a busy road!
 Hearing that so many of you are happy with Coach Net makes me feel a lot more comfortable - I got their Basic plan and I'll let you know if their service here in mid-Michigan is as good as it is elsewhere.
Thanks for all your replies!
Pat
Yahoo Message Number: 148263
"I checked my Progressive policy first, and while they do list towing, the wording made it sound very limited."
For what it's worth, when my Lazy Daze was struck by lightning a few years agoand was unable to run (due to a blown fusible link under the hood, as it turned out), Coach-Net would not pay for towing because it wasn't a roadside emergency mechanical failure--that's what they cover. (If the rig had been struck by lightning while driving, it might have been a different story.)
However, as it turned out, the towing clause in my Progressive full-timer's policy covers towing regardless of cause, and they paid for a 106-mile tow that would otherwise have cost me $478.
So if your insurance policy has no towing clause, or has a limited one, it's worth looking into adding that coverage. The cost per year is usually minimal, and it can save you a fair-sized chunk of money, as it did me.
Travels with Andy
Yahoo Message Number: 148265
Andy, I remember reading about your encounter with lightening! I'll have to double-check Progressive's wording again to make sure I'm covered.
 I'm wondering now if they will cover the brake issue as I'm not on the road, I'm parked at the shop where I do my stained glass... guess it's time to make a phone call.
Pat
Re: Progressive Insurance Roadside Coverage
Yahoo Message Number: 148271
I don't have fulltimer's coverage, just the basic coverage and it says Progressive will cover:
1. towing of a covered disabled vehicle to the nearest qualified repair facility; and
2. labor on a covered disabled vehicle at the place of disablement.
Read the fine print, however. There are caveats  qualifications and things they don't cover but it seems pretty standard language to me. Of course, one has to define "qualified repair facility".
Yahoo Message Number: 148272
--- Right. Some years ago, I had one tow experience in a previous RV; I was using the Good Sam road service clone from CW at the time. The  driver was told (by the dispatcher) to take the rig (and me, a passenger, and the dog, whom he suggested I leave in the rig while it was being towed! Yeah, that'll happen.) to a local RV shop on their list of "qualified repair facilities'. Since the problem was obviously a failed fuel pump, I suggested that it made no sense to tow the rig to an "RV shop", and asked him to tow the rig to the Toyota dealership (the rig was a little 1992 6-cylinder Dolphin). It took three back and forth calls to the dispatcher; we waited for well over an hour with the hooked-up-to-the-truck-rig in 100-degree heat on a Sunday afternoon before the road service agreed to tow the thing to the Toyota dealership, which was actually *closer* to the breakdown location than the RV place!
Sometimes one has to "negotiate" a bit to get to the *appropriate* "qualified repair facility". (The dog rode in the cab of the tow truck.)
As ever, YMMV.
Yahoo Message Number: 148273
"Read the fine print, however."
 Yup! And also bear in mind that with any insurance company, policies vary from state to state. My legal domicile is in Texas. A Progressive policy written on a vehicle registered in Colorado or California may very well have different coverages.
Travels with Andy
