Topic: Brake pedal "thump" when starting (Read 10 times) previous topic - next topic
Yahoo Message Number: 147855
My SOB uses the 2004 E450 chassis, same at the LD of that vintage.
Sometimes when I start it the first time for the day, I feel a "thump" in the brake pedal just as the engine starts. Later starts - no thump.
The brakes and everything else seem to work properly. Does anyone know what that "thump" is, and if it's a symptom of a problem?
Eric Greenwell
2005 Jayco 24SS
Re: Brake pedal "thump" when starting
Yahoo Message Number: 147856
I wonder if it is the hydro-boost rebuilding pressure that had bled off while the rig has sat for a while.
HTH, Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Yahoo Message Number: 147877
"I wonder if it is the hydro-boost rebuilding pressure that had bled off while the rig has sat for a while."
That's exactly what is happening. The hydro-boost assembly contains an accumulator which stores pressurized hydraulic fluid for use to brake the vehicle if the engine should stall. When new, a hydro-boost will hold pressure for days, even weeks. But after years of use it's check valves may not seal as effectively and leak down faster.
A test to see if the brake unit is pressurizing requires pumping the brake pedal several times, with engine off, until the pedal is rock hard.  Then, while holding your foot firmly on the pedal, start the engine. You should hear and feel a good thump in the pedal when the power steering pump reenergizes the hydro-boost.
Back to bountiful cell signals.
Yahoo Message Number: 147892
When I start it after several days, I get a sharp kickback in the pedal; if I do as Larry suggests, I get a softer kick. Perhaps pushing on the pedal several times until hard doesn't lose all the pressure, compared to sitting for week. Anyway, I think the hydro-boost must be it, and I'm assuming it's not safety or other problem, as long as it takes an hour or more to leak down. I'll try starting it an hour from now as a check on the leak rate: No kick - Good; get a kick - Bad.
Thanks, Larry.
 [lifewithalazydazerv] wrote, On 8/8/2014 11:54 PM:
2005 Jayco 24SS
