Topic: Location of coach water pump (Read 6 times) previous topic - next topic
Yahoo Message Number: 147462
I have a 1987 22' LD with bath and toilet in the rear.  The water pump for the internal water pump has died and I want to replace it.
However, I have no idea where it is.  Several people have suggested that I turn it on and listen for clicks; however, it makes not a peep.
Also, does anyone know what everflo model/size pump fits?
Any help would be appreciated.
Paulandjan44
Re: Location of coach water pump
Yahoo Message Number: 147474
I would look under the bottom small drawer on the kitchen cabinet.  Take out the drawer and it could be on the floor behind it.
Yahoo Message Number: 147476
"I would look under the bottom small drawer on the kitchen cabinet.  Take out the drawer and it could be on the floor behind it."
Water pumps are always mounted at floor level. In a Front Lounge it is most likely under the refrigerator/front wardrobe, next to the water tank. Start pulling drawers till you find it.
Some wardrobes have a removable bottom panel, exposing the pump.
Yahoo Message Number: 147482
There are screws that hold down the floor in the closet next to the refrigerator. Take those screws out and pry up that thin piece of plywood that acts as the floor. It should be in there. Once you see the pump, you'll be able to look at the model of it and search what a replacement would be.
