Adding TPMS monitoring to LD June 05, 2014, 06:42:12 pm Yahoo Message Number: 146782I added a TST TPMS to the LD 6? weeks ago. They got there first test over the May Holiday. 225 miles each way for 450 total miles. I like to run 80# in the rear and 70# in the front. But there was a problem with the sensors and my 5 tire pressure gages. The TST system said my testers were 4# to 5# high. So I went with 75 in the rear and 65 in the front. The 65 and 75 is still about 10+ high for the weight I have on the MH but in 11,000 miles the tires show no problem in wear. And as we all know the more air the better the mileage for fuel. If the tires do not give the miles that Michelin clams why care. I will never get 60,000 miles before the 6 years. More like 35,000 at most. So who do we thinkwe are fooling. Besides the first owner had 50,000 miles on the tires and there were still 10,000 miles left at the least. And he carried 80 and 70#. The only reason that I replaced the tires was I was going on a 10,000 mile tripto Alaska. Things I learned since the first trip. The suns heat will make a big difference when you inflate the tires the first time. If the sun in on the right side you will have more air in those tires than the left. The Suns rays will raise the pressure as you work. I would not have cough this except for the amount of time it took to fill the tires and checking the pressure several times. I inflated the tires off the MH so that I could set the sensor IDto the location. The TST system said to set the high pressure for 20% over the set tire pressure and the low at 10% below the set pressure.. So I had the 75 set at 90# and the 65# at 78#. The first part of the trip, 90 miles, are on I-25 so my speed after getting out of Denver was 65 MPH. Shortly after being at the higher speeds 3 of the sensors sounded the alarm that the pressure was to high. I turned the alarm off and keep on going. The pressure was to high not to low. You would not think that the tires would pick up 15# from driving. The tire tempiture was ok. On the return trip I also had 3 tires sound the high alarm. I have now added 3 # to all the tires for the high sensor warning.This should stop the warning for high air pressure.
