Topic: Sea Tech Fittings, Male Connector, ½\ (Read 9 times) previous topic - next topic
Re: [LD] Sea Tech Fittings, Male Connector, ½\
Yahoo Message Number: 145872
One thing to be careful of is that all the fittings need to be from the same manufacturers as there is a slight difference which can result in leaks.
Ian
2015 MB
Re: Sea Tech Fittings, Male Connector, ½" CTS x ½" NPT - Sea Tech
Yahoo Message Number: 145874
That looks to be the right size fitting. It's the same as the one I used recently, installing a new stainless steel sink.
https://www.flickr.com/photos/lwade/13192573915/in/set-72157642437590383 https://www.flickr.com/photos/lwade/sets/72157642437590383/ No need to go to CW, PEX push-on fittings are available at any decent hardware store and have been for years.
I use the SharkBite brand, available at Home Depot. They are metal, instead of plastic, not sure if it makes a difference but they have been trouble free so far. They are a good option for repairs and modifications and available five minutes away from home.
http://www.sharkbite.com/?gclid=CLLv18jA870CFe07OgodI3AAgQ http://www.sharkbiteplumbing.com/sharkbite-straight-connector-1-2-x-1-2-mnpt-lead-free
Re: Sea Tech Fittings, Male Conn ector, ½" CTS x ½" NPT - Sea Tec
Yahoo Message Number: 145876
One thing I would suggest when using something like Sharkbites, make sure you can access the fitting with two hands. Don't ask how I learned this....and the manufacturer did it to me !
20 + MH's since 1977 incl...
Past
FMC, 2x GMC's, Foretravel, 2x LD
Present
1996 LD RB under restoration, my project to keep me off the streets.
Yahoo Message Number: 145878
"One thing I would suggest when using something like Sharkbites, make  sure you can access the fitting with two hands. Don't ask how I learned  this....and the manufacturer did it to me !"
 Most, if not all, PEX push-on fittings require being pushed on the tubing firmly, a maneuver that usually requires both hands.  No magic here. Even the Factory-style crimp-on variety of PEX fitting needs access for two hands, if you are lucky enough get the calibrated PEX crimper into the needed location, thus the advantage of push-on fittings.
New lavatory faucet installation
Yahoo Message Number: 145915
Larry and all those that responded to my inquiry, I just completed the install of the new faucet on the bath lavatory using the brass push-on fittings using  12" stainless flex hose to make the connection to the new fixture. All work well and was very easy to accomplish. I posted the photos in my LWLD photo album, "Coachman's Enhancements -----."  As we dry camp a lot, I chose the lift handle style fixture to make it easier to open & close the water flow quicker. I also like the water flow forward presentation.  The only very minor drawback I found is if there is an air pocket in the water line, the air will squirt a small amount of water straight out toward one's pants in the wrong place. I quickly learned to deflect this when re-charging the water lines.
Thanks to everyone for their helpful input, Mike
2004 Born Free 26'
1998 Beaver Patriot 33'
1992 Barth Breakaway 28'
1982 Fleetwood Jamboree 23'
1982 Dolphin/Toyota 22'
