Topic: Coach Batteries Stolen (Read 9 times) previous topic - next topic
Yahoo Message Number: 145740
Hi Ray. Sorry to hear about the damage to your coach. I have a '99 TKB. If  you have a Ford E350 chassis, your '97 should be nearly identical to mine. Funny  thing is I've been planning to do this exact thing to mine intentionally.
I never liked that the battery tray didn't slide out all of  the way. A little battery acid over the side into the ball bearings has made the  slide out situation worse. The stiffness of the cables makes it hard to pull the  batteries out, and hard to get the bundles into the right location to push the  battery tray completely in. The vanity storage cabinet can be made shallower  without losing too much storage. (I've done the following in my prior coach). I  planned to cut out the back of the vanity cabinet and put a copper 3/8" buss bar  plate in to tie all of the plus side wiring together. Another plate to tie all  of the ground potential wires together. The 100 Amp resettable circuit breaker  would be relocated out of the battery box. A welder friend has donated some  finely stranded 2 Aught (00) welding cable that is relatively flexible. These  two cables would go from the buss bar plates into the battery box, suitably  color coded black and red. Only a single cable to each battery terminal. The  series jumper between the batteries could be stiffer as it was. I planned to  replace the old drawer slides with full extension drawer slides, rated for 200  lbs each pair. A new battery tray that would protect the slides from acid drips  would be made, powder coated. Slide 'barrel bolt' locks to keep the tray in  position. I hope to have enough room to put in T145 taller batteries and  still be able to service them easily because I could pull them all the way out  to see into the battery caps.
I was possibly going to put a whole house inverter in that  space also connected to the buss bars. Wiring to the power panel just next door  under the refrigerator would be easy. Cooling air vents on the side of the  cabinet into the doorway area could have small quiet fan forced air cooling when  the inverter was on. I just haven't got to this yet, but it looks like you have  the motivation to do it now. You would have to be comfortable working with high  power, thick cables and 12 volts. Insulation and proper metal and connection  techniques required. A good place to start a fire if it wasn't done just right.  I already have the 'pure sine wave' 400 watt inverter, and many of the parts I  would need.
If you elect to have it repaired like it was, the mother ship  would be a good choice. With my mods, it would be even easier to steal the  batteries again. The thief may even be waiting for new batteries to show up. Six  volt deep cycle batteries are sort of rare (unless you own a golf cart) and  heavy too. The thief didn't bother anything else? A better lock would be worse.  The painted access door probably would cost more than the batteries and  cables.
My Sympathy of course and I hope this was helpful.  RonB
Re: Coach Batteries Stolen
Yahoo Message Number: 145752
Yep, mines an E350 as well. You've sure given me a lot to think about, maybe it's time to turn this into an opportunity.
Thanks for your input, I'm going to weigh my options and start making phone calls tomorrow.
Thanks again, Ray
Formerly 1997 TK
