Topic: '87 Lazy Daze Coach water pump (Read 2 times) previous topic - next topic
Yahoo Message Number: 145581
Mine seems to be dying.
Does anyone know where it is located and how it can be removed?
Also, anyone know what kind and model it is?
Paul Diving Ms Daze, Willits, CA
Re: '87 Lazy Daze Coach water pump
Yahoo Message Number: 145583
"Mine seems to be dying.
Does anyone know where it is located and how it can be removed? Also, anyone know what kind and model it is?"
Paul
Most likely a Whisper King.
With no indication of what floor plan you own, it's location will continue to be a mystery.
Find the water tank's outlet and follow it to the pump's inlet.
 The pump.is screwed to floor and has hose clamp connections. Not hard to change once you find it and if you have the flexibility and dexterity to do the work in a confined space. Make sure to unplug the fuse, on the water pump circuit, before R&Ring the pump. A nut-driver, the size of the hose clamp screw, will make the job much easier.
Yahoo Message Number: 145584
Yahoo Message Number: 145585
"Does anyone know where it is located...?"
 Unless it's already dead, turn on the water and listen for the pump and go to the location where the pump noise is.
Yahoo Message Number: 145586
"Does anyone know where it is located and how it can be removed? Also, anyone know what kind and model it is?"
 As Larry pointed out, which floorplan? The location moved from year-to-year, and from model-to-model.
Yahoo Message Number: 145587
It should be next to the water tank. Turn the water on an lesson to where the sound of the pump is coming from.
Yahoo Message Number: 145595
"It should be next to the water tank"
 Not necessarily! in our '83 FL the pump was in the kitchen counter area, streetside, and the tank was under the couch, curbside. In our '04 FL, it IS near the tank.
