Topic: 81 front lounge grey h2o splashing up shower drain (Read 5 times) previous topic - next topic
Yahoo Message Number: 145262
Hi fellow Lazy Dazers,   Thought you all may be of help.   When the grey water level gets above 1/2 full when driving it splashes up through the shower drain.    Any ideas on how this happens and how to fix it.   Thanx, Hugh McCulloch      81 Front Lounge.
Re: 81 front lounge grey h2o splashing up shower drain
Yahoo Message Number: 145285
Hugh,
Are you sure your tank gauges are reading correct? Is the P trap still in place for the shower?  Is the vent pipe up top clogged?
 Does the tank drain quickly?  If the tank vent was clogged, it would drain real slow at first.  If you know the size of the tank, you could fill it with 5 gallon buckets at count how many go in and check the tank level on the read out as you go.  Perhaps the tank is really full and backing up as you drive around.
Ramon
2000 Mid-Bath
Yahoo Message Number: 145294
Your shower drain SHOULD have come with a screw-down drain strainer/plug. With both our '83 and '04 FL models we travel with it secured shut. With our '83, we sometimes even had it splash up through the bathroom sink, due to an air bubble shoving it up when sloshing around, so we kept that one secured as well.
Yahoo Message Number: 145295
Your shower drain SHOULD have come with a screw-down drain strainer/plug ----
My 2003 didn't come with a shower drain plug, just one for the wash bowl. ??? Joan
Yahoo Message Number: 145296
Same plug fits both shower, wash bowl and the kitchen sink as well in my 2003.
Joe Hamm
Yahoo Message Number: 145298
Well, I'll be....thanks, Joe!  ;-) Joan
