Topic: Refrigerator Latch solution (Read 12 times) previous topic - next topic
Yahoo Message Number: 144563
I found a latch system to keep my refrigerator and freezer doors closed while traveling.  It involves these baby-proofing clips:
 "Munchkin XTRAGUARD 2 Count Dual Action Multi Use Latches" that I found on Amazon Prime for $7.  2 come in the pack:
http://tinyurl.com/poo4m72
It attaches with adhesive, wraps around the corner, and swings down while not in use, leaving just a tiny white square on the fridge door.
It's a simple, inexpensive solution that will hopefully work well, as the spring on my refrigerator handle is broken.
I did see several other ideas online, like a window latch from Home Depot that you can screw onto the corners of fridge and freezer, but I wanted to avoid drilling into the fridge, although maybe a strong adhesive would secure it.
Just sharing in case it helps someone, Tessa in TX '92 MB- Ciao Baby!
Re: Refrigerator Latch solution
Yahoo Message Number: 144564
Tessa, I'm wondering why these latches are necessary. Both my 2003-vintage Dometic 3662 and my 2012-vintage Norcold N641 refrigerators had positive door latches--for that matter, so did Gertie's 2001-vintage Norcold--and I've never had a door pop open while traveling. But I assume you wouldn't have recommended these if you hadn't had a problem. Are your refrigerator door latches broken, or...?
Yahoo Message Number: 144569
I wish we could say the same, Andy. Here's a post from our web site a couple of months ago:
 My, my, what a delightful episode we had this morning. With the holiday season not so very far away, we had been talking about eggnog and how much we used to like it. So we decided to see if we mix up a home-brew version. It's really very simple: you just make sure that you have a brand-new full gallon of milk and a dozen fresh eggs. Then you merely start rolling along a rather hilly, twisting country road. Oh, one more requirement: you need to neglect to be sure the refrigerator door is securely latched. With a little luck, in just a few miles as you snake around one of those corners, the refrigerator door will fly open, allowing the gallon of milk and the dozen eggs to come flying out and smash together on the floor.
 All I'm hearing from my copilot is "Oh my God, we have a problem, we have a problem. Oh my God" I pulled over as soon as I could and what a delightful mess we had: milk and broken eggs sloshing all around. See - instant eggnog! What a time cleaning that all up - the milk had splashed everywhere.
 So after a stop to get more milk and eggs....and making sure the fridge door was latched....we continued southward.
WxToad @ Fort Bliss, TX
Posted by:  andybaird@... andybaird2000 Date: Thu Jan 16, 2014 6:48 pm ((PST))
I've never had a door pop open while traveling.  Andy Baird
Yahoo Message Number: 144571
Yes, the spring on the refrigerator door broke and now the latch just flops around.
If you have never experienced the refrigerator door flying open while traveling, then you are missing out on a really great adrenaline rush!  :)
Tessa in TX '92 MB Ciao Baby! (About to take 6 teenage girls up to Adopteen Camp in Ft. Worth! Wish us luck!)
Yahoo Message Number: 144572
The refrigerator door on my 2003 opened itself during a 'obstacle avoidance maneuver' to test the Safe-T-Plus steering stabilizer after installation at Henderson's.  The door swung out, and Stone IPA shot out across the floor and hit the cabinet; the caps of  three or four bottles popped off, spewing ale in fountains all over the vinyl floor, the carpet, and the cabinets.  Fortunately, none of the bottles broke, but the rig smelled like a brewery for several days!
Lesson learned: DO NOT overload the door of the refrigerator and expect it to stay shut! ;-)
Yahoo Message Number: 144573
Just yesterday on a very curvy, bumpy road leading to a BLM campground the side to side motion caused the frozen food to slam against the freezer door and everything poured out.  Not as messy as a gallon of milk, but after reading Tessa's solution I am considering buying the latches she recommends.
 Remember, I am the one who had the fridge  door fall off  several years back, so I don't trust those doors--they're out to get me.
Calicia
Yahoo Message Number: 144576
"the spring on the refrigerator door broke and now the latch just flops around."
The plastic latches on Dometic fridges are flimsy and badly designed. The one on my old Dometic 3662 broke some years back, but I was able to repair it. The short version: I welded the plastic pieces back together with a hot iron, then screwed the latch back onto the door. It held up for another four years or so, until I replaced the Dometic fridge with a Norcold N641. I've posted a few photos showing how the repair was done.
Tessa's solution is a quick and simple one that requires no tools. It does however, require that you remember to engage the add-on latches, so it probably wouldn't have prevented Ted's impromptu eggnog. ;-)
Yahoo Message Number: 144577
Having recently replaced a dead Dometic refrigerator, I discovered:  the latest Dometic model no longer has Climate Control or Low Ambient switches, nor does it have magnetic door latches.
Learning to adjust to soundless door closures via a teeny, tiny piece of plastic masquerading as a latch, has not allayed my fears that closing its doors is has secured the refer's contents!
It's bad enough that blueberries escape when simply opening the door after stopping -- but the thought of regurgitating eggnog or ale from the refer while under way?  On California roads?  AAAAK!  I just ordered a pair  of Munchkin latches.  Thanks, Tessa!
Lorna Back in sunny Coarsegold
2003 RB
