Eternabond roof sealant: Long-term performance? January 08, 2014, 01:28:51 pm Yahoo Message Number: 144441I know some of you have used Eternabond roof sealing tape. So I'm wondering how it's holding up long-term. Does it appear to be a permanent fix, or near-permanent? Have you had to replace it ever? Is it still sealing?Thanks! :-)
Re: Eternabond roof sealant: Long-term performance? Reply #1 – January 09, 2014, 10:37:54 am Yahoo Message Number: 144450I've had the Eternabond on our LD roof for the past five years. Never a leak. It's been fantastic!On Wednesday, January 8, 2014 11:28 AM, "maweiser@..." wrote:
Re: Eternabond roof sealant: Long-term performance? Reply #2 – January 09, 2014, 11:14:04 am Yahoo Message Number: 144451I don't know about 'permanent', but a roof seal job using Eternabond tape (either the 4" or 6" widths) can last a long time *IF* the surface preparation is correctly and meticulously done. If prepping the to-be-sealed seams and surfaces is sloppy and/or 'short-cutted' (including making sure that the roof screws are not 'popping'), poor results, i.e., bubbling, not sticking, edge-lifting, are inevitable.The seam seal between the roof and the overcab on my 2003 was a poor job from delivery; I cleaned out the bubbled, dirty-water-filled pockets in the goopy sealant, prepped the surface, and applied a strip of Eternabond. The only reason that I 're-stripped' this seal when I did the complete roof about three years ago was that a low-hanging branch had snagged a couple of little rips in the original Eternabond; the stuff is not impervious to cuts, scrapes, and holes being poked through it.So, yes, Eternabond lasts, but be sure to prep the surface well before carefully applying it (remember, there are no 'do-overs' with this stuff!) and check periodically for any loss of 'integrity' in the seal.As ever, YMMV. Joan
Re: Eternabond roof sealant: Long-term performance? Reply #3 – January 09, 2014, 06:40:08 pm Yahoo Message Number: 144453Thanks for the replies, good info. I presume Eternabond recommends a cleaning procedure before applying the tape. But can you suggest a method that worked for you?
Re: Eternabond roof sealant: Long-term performance? Reply #4 – January 09, 2014, 07:33:56 pm Yahoo Message Number: 144455Matt, you might want to check the Lazy Daze Companion for some how-to Eternabond information:http://lazydazearticles.blogspot.com/search/label/eternabond
Re: Eternabond roof sealant: Long-term performance? Reply #5 – January 10, 2014, 01:32:52 pm Yahoo Message Number: 144456If you have your rig professionally washed don't let them use a high pressure wash on the roof. Some of those sprays have enough force to go right under the eternabond.
Re: Eternabond roof sealant: Long-term performance? Reply #6 – January 10, 2014, 02:08:11 pm Yahoo Message Number: 144457"...don't let them use a high pressure wash on the roof..." ---JMHO, but I suggest not using a pressure washer *anywhere* on one's rig; there are multiple 'vulnerable to high-pressure water penetration' areas, i.e., the refrigerator, water heater, and battery compartments, the seals around the windows, the storage compartments, and likely a few more areas, too.As ever, YMMV, but after seeing the 'layers' that a neighbor peeled off the surface of his driveway with one of these things, I'll stick with a carefully-wielded garden hose for rig cleaning! ;-)Joan
