Corner Molding Seam Repair December 21, 2013, 11:29:14 pm Yahoo Message Number: 144228Hi, The exterior rear seams on my 2002 MB between the corner moldings and the sides of the RV have begun to open. What is the recommended material and procedure to repair this?ThanksDavid & Wendy
Re: Corner Molding Seam Repair Reply #1 – December 22, 2013, 09:02:44 am Yahoo Message Number: 144230This is a common problem with LD's and to me it represents a flaw in the design and materials. The siding is aluminum and the end caps are plastic - different expansion and contraction rates. Thus the adhesive (and Ld has used several over the years, I believe) fails. They ought to make the end caps of formed aluminum; I'd gladly pay the added cost. Anyway - how to repair: I had a major separation of one of the front corner pieces a few years ago. With VERY helpful advice from Larry W. I was able to repair it myself. I documented the process with pictures and words.Good luck.WxToad Posted by: "Wendy Harris" dwjharris@... dwjharris Date: Sat Dec 21, 2013 9:29 pm ((PST))The exterior rear seams on my 2002 MB between the corner moldings and the sides of the RV have begun to open. What is the recommended material and procedure to repair this?David & Wendy
Re: Corner Molding Seam Repair Reply #2 – December 22, 2013, 11:04:45 am Yahoo Message Number: 144235Windy You do need to address this before water enter the framing and any(more) damage occurs.. The Mothership is happy to repair or replace the molding, plan on a big bill. The caps can be reattached by a through cleaning of the adhesive tape, used for attaching the cap, and then gluing then in place using clamps, screws or whatever means to hold the caps in place while the polyurethane cures. I use 3M 5200 Fast-cure polyurethane. Search the archives for more detail instructions, from my previous postings.Larry
