Topic: RV Hydro Flush - Does it Work With an Elbow (Read 6 times) previous topic - next topic
Yahoo Message Number: 143999
Is anyone using the Valterra 45 Degree RV Hydro Flush with any success on a LD that has the 90 degree elbow in the drain pipe?  I know this product works best with a straight shot into the tank, but our LD (2010 31' split bed)has an elbow.  I searched through the forum, but couldn't find any specific comments about this product's performance in our situation.
If needed, here is the link to the product at Camping World.
http://www.campingworld.com/shopping/item/rv-hydro-flush-45-degree/14496#sthash.sj48mDBE.dpbs
Re: RV Hydro Flush - Does it Work With an Elbow
Yahoo Message Number: 144006
I use a 45° HydroFlush with my midbath, which has a bend in the pipe between the dump valve and the tank. It doesn't work as well as in my older LD, which had a straight pipe going into the tank, but it's still quite effective. It certainly beats snaking a hose in through the bathroom window every time you dump! I haven't done that in years.
Yahoo Message Number: 144012
Hydro-flushes only work well when there is a straight shot into the tanks. When turns in the drain pipes are present,  in-tank flushers can be used to clean the insides of the holding tank.
The Campco flusher is commonly available and been used for years. Our LD has used a pair of them for ten years and seem to do a good job.
http://www.amazon.com/Camco-40123-Quickie-Flush-Preventer/dp/B000EDOSME
http://www.flickr.com/photos/lwade/sets/72157602104741465/
If you have an old hydroflush, you can use it to make one of these.
http://www.flickr.com/photos/lwade/sets/72157602095132874/
Yahoo Message Number: 144017
Thank you for the quick responses and links to photos/websites.  I sort of figured I was going to have to install something into the tank.
Tim
Yahoo Message Number: 144023
"I sort of figured I was going to have to install something into the tank."
 I've been using a Flush King with good results.  A search of this group shows several messages on the subject.
Howard
Yahoo Message Number: 144033
Waiting for Feb/Mar 31 IB PU.....
 I've was going to build something like the link below until I saw this for about $20 at Cramping World:
http://www.campingworld.com/shopping/item/flexible-tank-wand/14497
It works, but is still 'hose thru the window"....
No seriously considering some of the alternatives mentioned in this thread. joel
From: rivercrest99 To: lifewithalazydazerv@yahoogroups.com Sent: Tuesday, December 10, 2013 9:22 AM Subject: [LD] Re: RV Hydro Flush - Does it Work With an Elbow
dog Zeke
Yahoo Message Number: 144038
My vote is no. Three reasons:
1. Hose through the window = pain in the ass.
2. After you've used it, you now have this four-foot-long thing that has just been down the filthiest hole in the rig. What are you going to do with it? How are you going to store this large, crap-covered object in a sanitary fashion?
3. Back when my Lazy Daze had a toilet that dumped straight down into the tank, I tried a straight wand of this general type. It was all but ineffective at cleaning the tank. Then the top fitting snapped off, spraying me and the bathroom with water until I could get outside to shut off the hose.
I'll stick with my HydroFlush.
Yahoo Message Number: 144077
I don't disagree
Subject: Re: [LD] Re: RV Hydro Flush - Does it Work With an Elbow
dog Zeke
