Topic: Frozen Outside Bin Doors (Read 3 times) previous topic - next topic
Yahoo Message Number: 143979
Oh wise ones,  How do I prevent my outside bin doors from freezing shut?  We're having an unusually cold snap here in western Washington and my outer bins are frozen shut. Unlike previous occasions, there isn't an obvious ice flow across the doors. It appears the gaskets are freezing shut. Tricks? Tips? I need to use the rig this winter... There's got to be a trick--too many of you use your rigs year - round.   Lori Y 2011 24FL
Lori Y
2011 24FL
Re: Frozen Outside Bin Doors
Yahoo Message Number: 143988
Joe's response was good.  Here is more.
 The cabinet doors will only freeze shut if there is moisture there.  That moisture can come from rain (you get that up there, right? ) or from condensation.  It is key to prevent moisture from STAYING there.  That means first, the gasket and the door edge must be absolutely clean.  Dust will hold moisture.  Once it is clean, you want something there that will shed moisture.  The owner's manual recommends a thin film of vaseline, which will work.  I don't know if 303 protectant will do the same.  It needs to be on both surfaces, so that if moisture appears, it is "rejected" by the surface, thus beading and running off.
 If 303 does this, it is a good choice because it dries and will not attract dust like vaseline.  I use vaseline because I can control it better and keep it off the finish.
 When I do it, I start with hot, soapy water and a rag.  I thoroughly clean both surfaces, then rinse with clean, warm water and dry.  I then do a wipe with isopropyl alcohol on a rag and clip the door open to dry thoroughly.  Finally, I put a little vaseline on a finger and rub it onto the surface.  There should be enough that the surface has a slight shine from the vaseline, but no real thickness or accumulation.  I remove excess by wiping with my finger.  That's it.
Ken F in NM
Yahoo Message Number: 144014
I've had good luck with spray silicone on all door gaskets.  After they are clean I either spray them or spay a rag and wipe it on.
It will climb from 4 below last night all the way to 16F today!
Yahoo Message Number: 144027
Thanks to all. I'll try a good cleaning & 303 once the weather lets me open them. ...then silicon...then vaseline. But I think 303 will work.
Lori Y 2011 24FL
Lori Y
2011 24FL
Yahoo Message Number: 144028
Lori, in my experience, using 'vaseline' or any petroleum jelly to lube seals or dump valve parts or any 'rubber' components isn't effective and usually creates a sticky, dirt-collecting mess. I suggest using 303 or silicone spray; effective, and neither attracts dirt.
As ever, YMMV.
