Topic: SeaLevel Gauges Install (Read 14 times) previous topic - next topic
Yahoo Message Number: 143932
Has anyone installed SeaLevel Tank Monitor Gauges in a newer mid-bath.  Pros and cons on the install and the unit itself welcome.
Ron 2011 MB
Betty/Ron
Re: SeaLevel Gauges Install
Yahoo Message Number: 143940
The SeeLevel 709 has been in used for over decade is a well proven, accurate device. Many members here have one installed.
Installation consist of running wires from the tanks to the panel, using either separate wire or a common bus. The panel is usually installed near the stove for access to the propane tank level wire and 12-volt.power. Tank sensors should be temporaily taped down, with masking tape, until calibration can be confirmed by filling and draining of the tanks.
It's a good day's work to install and calibrate. Difficulty of wire runs can add extra time. With LD's habit of changing little things, from year to year, it's near impossible to predict how easy or difficult your model is with first determining how the wires will be run.
I have nothing bad to say about them except that the sensors are easy to a damage if mishandled. Once permanently installed, they are very durable.
