Topic: Display Lights Quit Working 2000LD (Read 8 times) previous topic - next topic
Yahoo Message Number: 143905
Yesterday, after we moved locations the "Readout Display and  (Water Heater Lights and Heater does not ignite)" quit working.  The Generator, Hood Light and Fan and Pump and light work just fine.  I pulled the panel out and made sure the connections were secure and checked all breakers.  We had gone from Shore power to Battery and inverter, however all other systems on electric are working perfectly...even the frig will work on electric if I ask it to.   I did not see any in-line fuse, so I have no idea since the (water heater indicator light and power switch) and readout display are separate units.  I would otherwise suspect the readout board went bad.  This is a 2000LD 26.5 MB.  Any ideas?  Thank you in advance.
Doug, Beth and Heidi
2000 26.5 MB and 2012 Sonic Toad
Re: Display Lights Quit Working 2000LD
Yahoo Message Number: 143911
Hi Doug, if I was you I would call Vince and see what he says. You  can't be the first one this has happened to. There is a good RV place in Prescott by the way. Not the new big building but further south on the 69. Forget the name. Have fun, john
On Tuesday, December 3, 2013 10:23 AM, Doug Koss  wrote:
