Topic: 94 26rb passenger side leaning (Read 5 times) previous topic - next topic
Yahoo Message Number: 143521
Has this happend to anyone? Ld is leaning abt 3 inches down on pass side. Level ground. Ride rite both sides little effect. What was cause in your case? 30 k miles on rig. Tires at pressure needed.
Thanks -- Sent from mobile
Re: 94 26rb passenger side leaning
Yahoo Message Number: 143523
I would want LOTS more info but my first thought is either a broken spring or damaged mount somewhere in the system on the right.  Most likely, with that much lean, there is a broken leaf or 2 on the right rear spring.
Ken F in NM
Yahoo Message Number: 143524
My own first thought is a failed Ride Rite airbag. Third-party suspension add-ons are significantly more failure program than suspension parts designed into the chassis by Ford.
Yahoo Message Number: 143532
Thanks all. Put on road. Whats funny is when i picked up fr storage i heard what sounded like a shotgun blast. Lots of shooting so i knpw the sound. It sounded distant so i didnt think iy was me . Now not sure.
 Drove 100 mo last night good performance. Visually under chassis springs look good both sides.  Bilsteins of unknown age.  Pass side rde right had different spacers than other.
Measured diff is 2 inch not 3.
Never noticed before but may have been that way.
Thanks !
Yahoo Message Number: 143534
Remember that shock absorbers do not support any weight. Their job is to suppress movement.
Dick
Yahoo Message Number: 143535
"Has this happened to anyone? LD is leaning about 3 inches down on pass side''
Matt
Have all four corners weighted. The 1994 26.5' is built on the lightweight E350 chassis, with its minimal 11,000-lbs GVW,  and is almost fully loaded when bare. A few hundred pounds imbalance toone side will cause it lean.
 A twenty year old motorhome could easily have worn out or broken springs so if it isn't an imbalance, you may need the springs replaced or rebuilt.
Yahoo Message Number: 143536
"Whats funny is when I picked up fr storage i heard what sounded like a shotgun blast "'
A air bag blowing up would make a similar noise.
Yahoo Message Number: 143540
If you can't determine the cause before you do any driving, I suggest you take it to a shop that is familiar with the chassis. A broken spring or other suspension part is potentially very unsafe, and I would not drive it farther than the nearest shop.
Eric Greenwell
Matt W. wrote, On 11/9/2013 1:27 PM:
2005 Jayco 24SS
Yahoo Message Number: 143570
Chalk it up to a little syndrome called hyper-vigilance. The suspension is fine; the tanks need recognition in their contribution toward balance too.
Thanks all.
